Countdown To Christmas!
Similar Content
By 12Horse Paladin
So i have paper that says my new to me Bronco 14 Automatic was/is a 1970; PO (im the 3rd owner now) says it's a '71 from info they found.
Which is it; and which section of the forum downloads section holds this info, if i may ask (i am not good at navigating/using that section on this phone...)?
Ive added a pic, but i cant really make out that last number of the model #, way to the right...?
By 69-Raider-10
Just brought her home an hour ago! Ran it through the paces and everything checks out! Now shes coming in the shop to get a good tune up, the Bolens plow taken off and replaced, fluids change, some rewiring, a motor cleaning and a couple of new gaskets, and a good carb cleaning. And maybe some fuel lines. 😁 This is my first hydro so its taking some getting used too. LOVE the hydraulic lift though! Dont know how I lasted this long without one!
By sfjohnson722
Greetings all, first post to this forum.
I am in the process of getting my father's 1971 Bronco 14 (1 0421 6) up and running. After pulling the hydrogear for reworking, I noticed some lash between the rear wheels when on jackstands. I found one of the hubs to be badly worn, but also noticed there seems to be a clicking or ratcheting when turning one side at a time (whether the parking brake is on or off). The opposite wheel does turn in the opposite direction - it just does so with a click / ratchet feel. I was expecting something smoother like with an automobile differential. Is this normal? Should I plan to split the case, and if so what should I be looking for?
Thanks in advance for any information!
By redhorse71
Hi Iam new to this forum and looking for help with our 1971 bronco 14 tractor model number 1-0421, this is my dad's tractor and Iam trying to help him with looking for answers or parts for it.
the problem is the blades are not engaging and he thinks it has to do the the clutch? okie so the problem is where do i find a new clutch for this old model or? Do you think there is something else we should be looking for as to why the blades are not engaging. I have been looking online for parts but iam not getting far without a parts number erggg. and toro is no help already called them.
thanks in advance for taking the time to read this , he does love his bronco!
