Stepney 2,357 #1 Posted November 13, 2019 Saw this little guy show up on the local classified page we need not mention. Listed for 75.00. Last thing I need is another project but .. I called anyway. Couldn't make time work and talked myself out of it. Just this morning, the fellow calls and says to take it or leave it, 25.00, its headed to scrap if it doesn't go. Well we can't have that.. so off I went. I haven't checked the build plate but he believes it's a 1971. Charger 12, obviously. It was family owned since new. Parked in 1992 when a deck pulley rounded off. Apparently uncovered, and untouched since that day. Square rubber WH key remains in the ignition. Engine does turn over, deck is there but a bit worse for the wear. It has a Solid State Ignition K301 in it which supposedly ran when parked. Interested to see if it's actually still working. Not quite sure what'll happen with it just yet, but here she is! Couldn't stand for it to be crushed. 4 8 1 Share this post Link to post Share on other sites
ebinmaine 77,343 #2 Posted November 13, 2019 Well done sir 1 Share this post Link to post Share on other sites
ZXT 2,401 #3 Posted November 13, 2019 (edited) Very cool save! Those deals are the best. Looks like it'll clean up nicely and make a good worker. It's been out of service for longer than it was in use! Did that Stover come from the same person? EDIT: Maybe it isn't a Stover. Hopper looks a little different. IH maybe? Edited November 13, 2019 by ZXT Share this post Link to post Share on other sites
Stepney 2,357 #4 Posted November 14, 2019 59 minutes ago, ZXT said: Did that Stover come from the same person? EDIT: Maybe it isn't a Stover. Hopper looks a little different. IH maybe? International Harvester Famous 1hp in fact. Just chilling in the back of the truck till I get a minute to unload it. Needs a complete overhaul it's pretty well tired and cobbled. 1 Share this post Link to post Share on other sites
953 nut 64,124 #5 Posted November 14, 2019 22 minutes ago, Stepney said: back of the truck till I get a minute to unload it May as well leave it in the truck till spring, added weight for traction! Nice save on the , bring it to the Big Show in June and I would be glad to double your money ($ 50). 1 Share this post Link to post Share on other sites
Pullstart 68,883 #6 Posted November 14, 2019 I was gonna offer triple your money! 1 Share this post Link to post Share on other sites
rjg854 12,846 #7 Posted November 14, 2019 can I hear 2 hundred 3 Share this post Link to post Share on other sites
Tractorhead 9,216 #8 Posted November 14, 2019 Good that you saved it from the yard. i doesn‘t look that bad at the Pics, ok bit of Work must surely be done. But about that Price, it‘s worth to spend a bit Invest to bring it back to Life. 👍 1 Share this post Link to post Share on other sites
Retired Wrencher 6,451 #9 Posted November 14, 2019 Stepney That will make a great project. Find a spot out of the weather. I would think you are in no rush for it`s completion. on the save. 1 Share this post Link to post Share on other sites
pfrederi 19,881 #10 Posted November 14, 2019 One nice thing about breakerless long term sitting isn't a problem for it. No points to corode Share this post Link to post Share on other sites
12Horse Paladin 1,038 #11 Posted November 14, 2019 WOW. Nice save...incredible deal!...indeed!👍 Enjoy! Share this post Link to post Share on other sites
Stepney 2,357 #12 Posted November 15, 2019 This machine is very much a mixed bag. Logically i has a fraction of the runtime of most machines. Looking down bore confirms that. No carbon buildup, nice golden brown H10 plug, no wear on the starter gear. Tank cap crumbled in my hand but inside of the tank is spotless. Clean oil in both the engine and trans. That's where everything stops. One rear hub has destroyed itself and has a bolt through it, was shimmed with a piece of pipe, destroyed itself, the axle, and the trans housing further. Other side isn't much better. The deck continues with the same logic. The housing is rusted badly and smashed up. Axle bracket, hitch, and all linkage has broken many times and been repaired. Yet .. perfect, still sharp blades on it, and the spindles are smooth and tight. 1 1 Share this post Link to post Share on other sites
ebinmaine 77,343 #13 Posted November 16, 2019 Hey you gotta put that hub video on YouTube and post it here..... Share this post Link to post Share on other sites
pfrederi 19,881 #14 Posted November 16, 2019 Cracked ignition coil is not promising but they are easier/cheaper to find than the trigger assembly. When you open her up test test the trigger per manual. if it pass i can fix you up with a coil. 1 Share this post Link to post Share on other sites
Pullstart 68,883 #15 Posted November 16, 2019 My offer has just gone down a bit.... I’m sure you’ll get this one fixed up in no time... but wow! Share this post Link to post Share on other sites
