mach1970 0 #1 Posted November 13, 2019 Good Morning Everyone, I am looking for a plow for my Wheel Horse GT2500. There are several for sale locally to me, but I am not sure which one will work with my tractor. Most say "fit for small frame" or "fit for large frame". Will one of these work or do I need something special? Thanks, Rob Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,196 #2 Posted November 13, 2019 Your tractor is a long frame model. Here are the blade model numbers in the order they were produced. The 1982 blade was 06-42BC02. Anything since then will definitely fit with older models possible requiring a minor twik to the angle lever. Rear axle mounting brackets part of the blade assembly also required and often separated when blade is removed from the tractor. 1968 model 6-4111 - First to fit LONG & SHORT frame tractors and first to mount under the rear axle - replaced by 1969 model [6-4112 + 6-9621] 1970-73 model [6-4113 + 6-9622] 1973-74 model [6-4113 + 6-9623] 1974 model [6-4114 + 6-9624] 1974 model 6-2131 1975 model 6-2132 1976 model 6-2133 1976 model 66-42BC01 1977 model 76-42BC01 1978 model 86-42BC01 1979 model 96-42BC01 1980 model 06-42BC01 1981-1984 model 06-42BC02 (Up to here including this one they are 42" wide) 1984-1989 model 06-48BC01 (They are now 48" wide) - replaced by the following 1990 model 06-48BC02 1991-1993 model 06-48BC03 1993-2001 model 79350 - (105-1502 kit adapts 2001 and older GT Classic-Series blades to fit 2002 and later tractors 2002 2004-2009 2012 model 79364 - (105-1501 kit adapts 79364 blade to fit 2001 and older GT Classic-Series) Garry 1 Share this post Link to post Share on other sites
953 nut 65,693 #4 Posted November 13, 2019 If you don't already have one, the dozer blade/snow plow attaches to an axle bracket on the rear axle housing. Be sure the seller is including it in the price of the snow plow. Share this post Link to post Share on other sites
mach1970 0 #6 Posted November 14, 2019 Thanks for the information guys, I appreciate it. Rob Share this post Link to post Share on other sites
mach1970 0 #7 Posted November 30, 2019 Hey Guys Found a plow model 79251. It is not listed in the post above. Would this fit my GT2500? Thanks, Rob Share this post Link to post Share on other sites
Sparky-(Admin) 25,163 #8 Posted November 30, 2019 1 hour ago, mach1970 said: Hey Guys Found a plow model 79251. It is not listed in the post above. Would this fit my GT2500? Thanks, Rob Nope. That plow is for a 200 series vertical shaft lawn tractor. Share this post Link to post Share on other sites
