AHS 1,594 #1 Posted November 11, 2019 Its my 310-8. I don’t know what year, cause I can’t find the serial number! With the short Shute snowblower... converted to a long shute (I thought it would throw snow father.. but It did not) and my daughter on the wheel horse!😁 3 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #2 Posted November 11, 2019 1987, 1988 or 1989. Post the serial number off the engine decal and it may narrow it down. Kohler M10S-461521 Garry 1 Share this post Link to post Share on other sites
wallfish 19,303 #3 Posted November 11, 2019 1 hour ago, AHS said: . converted to a long shute (I thought it would throw snow father.. but It did not) It appears the tall chute was added on to the original chute. The taller chutes do fly snow farther because it flies almost straight up before the curve. With the curve in the chute low, it hits the chute harder before exiting which slows it down. 4 Share this post Link to post Share on other sites
SPINJIM 1,996 #4 Posted November 11, 2019 You would have to replace the LOWER part of the chute, as well as the upper, to get the benefit of the tall chute. Good luck. No snow here yet, but I fired up my plow today just in case. 2 Share this post Link to post Share on other sites
AHS 1,594 #5 Posted November 11, 2019 1 hour ago, wallfish said: It appears the tall chute was added on to the original chute. The taller chutes do fly snow farther because it flies almost straight up before the curve. With the curve in the chute low, it hits the chute harder before exiting which slows it down. Ya, I took off the top of the short shute, and then dropped the long shute inside the lower short shute.... anyways there is too much curve to it.. it’s worked for two years. Share this post Link to post Share on other sites
AHS 1,594 #6 Posted November 12, 2019 2 hours ago, gwest_ca said: 1987, 1988 or 1989. Post the serial number off the engine decal and it may narrow it down. Kohler M10S-461521 Garry That’s where it i on my 2000... I looked there! Maybe it’s lost.... before I got it! Share this post Link to post Share on other sites
wallfish 19,303 #7 Posted November 12, 2019 1 minute ago, AHS said: Ya, I took off the top of the short shute, and then dropped the long shute inside the lower short shute.... anyways there is too much curve to it.. it’s worked for two years. Cut that original portion shorter so the tall shoot stands straight up. You'll get more distance Share this post Link to post Share on other sites
AHS 1,594 #8 Posted November 12, 2019 1 minute ago, wallfish said: Cut that original portion shorter so the tall shoot stands straight up. You'll get more distance The whole tractor is for sale, with the top part of the short shute and a 42”sd mower Share this post Link to post Share on other sites
AHS 1,594 #9 Posted November 12, 2019 I got a tall shute, single stage. I replaced all the bearings, new sprocket on the auger and new paint... not totally together... paint and primer take time! 1 1 Share this post Link to post Share on other sites
