fwj 1 #1 Posted November 11, 2019 can a newer and cheaper rectifier be retrofitted ? I have the square one with a pigtail. a new one is $ 116.00. will the wrong/cheaper one not work right such as over charge the battery or damage the stator ? Share this post Link to post Share on other sites
The Tuul Crib 7,340 #2 Posted November 11, 2019 (edited) to Shouldnt hurt at all make sure it is the correct amperage that you need .Usually a 15 amp. Edited November 11, 2019 by The Tool Crib Share this post Link to post Share on other sites
rmaynard 16,700 #3 Posted November 11, 2019 I would never pay that much for a reg/rec. If it is one of the aluminum ones with fins, I get replacements from Milford Power: https://www.milfordpower.com/R10297-Voltage-Regulator-Replaces-Kohler-41-403-06-p/r10297.htm You can also find some on Amazon. 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,897 #4 Posted November 11, 2019 AND... I have two C105’s - they are great! Love the Black Hoods! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,853 #5 Posted November 11, 2019 The small ones need to be fan cooled. That is why they are mounted in the flywheel blower housing. Garry 1 Share this post Link to post Share on other sites
Achto 30,217 #6 Posted November 11, 2019 Here is another source for a voltage regulator. http://www.psep.biz/store/kohler_voltage_regulator.htm Share this post Link to post Share on other sites
WHX?? 53,381 #7 Posted November 11, 2019 (edited) Or do you have the small square one with the mounting hole in the middle? Molded in leads coming out in terminating in a two term. connector? That's what is on my C-125 not like the style you guys have on your tractors and posted links to. I definitely don't have one like on your 145 Dan @Achto. I was thinking of replacing it as it tends to run at 15.5 - 16 volts. My bad no pics of it other than IPL. WH/Toro 109313 rectifier Yah Toro is quite proud of them. https://www.repairclinic.com/PartDetail/Rectifier/109313/2144845 Just one of many I found same price range. Parts tree @ $133 !!! Some research on a Chinese one or retrofit is in order. Bingo if this is what you are looking for fwj. https://www.ebay.com/itm/ELECTRICAL-RECTIFIER-WORK-PRO-711522011-109313-TYMPANIUM-CORP-N-O-S/323837832942?hash=item4b663d2eee:g:pTMAAOSw7l1dCT2p Edited November 12, 2019 by WHX24 1 Share this post Link to post Share on other sites
953 nut 63,130 #8 Posted November 12, 2019 Looks like you have the information you need here. What model do you have, Like the truck in your avatar, I have a '48 Ford F1, been driving it over thirty years. Share this post Link to post Share on other sites
fwj 1 #9 Posted November 12, 2019 (edited) thanks for all the help. I ordered the one on ebay. Edited November 12, 2019 by fwj 1 Share this post Link to post Share on other sites
WHX?? 53,381 #10 Posted November 12, 2019 Your .... let us know how it works please. Share this post Link to post Share on other sites
Achto 30,217 #11 Posted November 12, 2019 20 hours ago, WHX24 said: I definitely don't have one like on your 145 Dan @Achto. I was thinking of replacing it as it tends to run at 15.5 - 16 volts. I could be wrong but that unit looks like it is only a rectifier. I believe that Kohler ran something close to what Briggs does for a little while. No voltage regulation, just a lower amp AC stator and a rectifier or diode to change the voltage to DC. This may be why you are metering a little high at the battery. If your not cooking the battery, I wouldn't worry about it. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,853 #12 Posted November 15, 2019 Click on picture for more Garry 2 Share this post Link to post Share on other sites
WHX?? 53,381 #13 Posted November 15, 2019 On 11/12/2019 at 10:33 AM, Achto said: looks like it is only a rectifier. I believe you may right Dan no regulation just some DC being flung at the battery & lighting. I replaced the questionable ampmeter with a 12 dollar digital volt meter so keep an eye on it. As little as this tractor will get worked at this point I doubt batteries will get cooked. Running with the lights on helps keep the voltage down. It would not be a project to replace it with one Garry has shown above. Share this post Link to post Share on other sites
fwj 1 #14 Posted November 19, 2019 On 11/12/2019 at 10:39 AM, WHX24 said: Your .... let us know how it works please. Share this post Link to post Share on other sites
fwj 1 #15 Posted November 19, 2019 just put it in 13.6 at idle. 14.5 volts to battery at 3/4 throttle . thanks for all help and links to new old stock rectifier for under $ 10.00 what a find. Share this post Link to post Share on other sites
fwj 1 #16 Posted November 19, 2019 On 11/11/2019 at 3:04 PM, WHX24 said: Or do you have the small square one with the mounting hole in the middle? Molded in leads coming out in terminating in a two term. connector? That's what is on my C-125 not like the style you guys have on your tractors and posted links to. I definitely don't have one like on your 145 Dan @Achto. I was thinking of replacing it as it tends to run at 15.5 - 16 volts. My bad no pics of it other than IPL. WH/Toro 109313 rectifier Yah Toro is quite proud of them. https://www.repairclinic.com/PartDetail/Rectifier/109313/2144845 Just one of many I found same price range. Parts tree @ $133 !!! Some research on a Chinese one or retrofit is in order. Bingo if this is what you are looking for fwj. https://www.ebay.com/itm/ELECTRICAL-RECTIFIER-WORK-PRO-711522011-109313-TYMPANIUM-CORP-N-O-S/323837832942?hash=item4b663d2eee:g:pTMAAOSw7l1dCT2p Share this post Link to post Share on other sites
fwj 1 #17 Posted November 19, 2019 just put it in. works great. new old stock. 13.6 at idle 14.50 volts at 3/4 throttle . looks just like original. thanks for that link. Share this post Link to post Share on other sites
