Mudrig150 353 #1 Posted November 8, 2019 I want to add a rear worklight to my 317 and 140, and I have 2 requirements. 1. Don't want to drill holes in the body, frame don't matter to me 2. I want a 2 position light switch, off, headlights, headlights+worklight Any suggestions? Share this post Link to post Share on other sites
shallowwatersailor 3,216 #2 Posted November 8, 2019 Look for a magnetic base for the worklight. Northern Tool sells them. Placing the light down low on the frame probably won't do much for illumination. Share this post Link to post Share on other sites
Mudrig150 353 #3 Posted November 8, 2019 (edited) Wait- Wanted to make this thread in electrical. Oops. Also just realized there's already holes in my fenders to mount the light to, theres 2 that were for the radio mount, and one at the back for the wierd base thing, the thing next to the taillight. Edited November 8, 2019 by Mudrig150 Share this post Link to post Share on other sites
Pullstart 68,174 #4 Posted November 8, 2019 (edited) with the use of a diode, a single pole double throw (three position) switch could be made to work. The diode will allow electrical travel in only one direction so having the headlights powered in both on positions without powering the work light too. here’s a quick sketch of what I mean. Edited November 8, 2019 by pullstart Drawing 2 Share this post Link to post Share on other sites
Mudrig150 353 #5 Posted November 8, 2019 10 minutes ago, pullstart said: with the use of a diode, a single pole double throw (three position) switch could be made to work. The diode will allow electrical travel in only one direction so having the headlights powered in both on positions without powering the work light too. I know there are the simple ON-OFF-ON switches, might just use one of them and connect the headlight to both terminals and the worklight to the lower one. Share this post Link to post Share on other sites
Pullstart 68,174 #6 Posted November 8, 2019 Without the diode, I’m pretty sure both circuits will be powered when you flip either switch... Share this post Link to post Share on other sites
Mudrig150 353 #7 Posted November 8, 2019 1 minute ago, pullstart said: Without the diode, I’m pretty sure both circuits will be powered when you flip either switch... Oh, you have a point. Share this post Link to post Share on other sites
Mudrig150 353 #8 Posted November 8, 2019 https://www.amazon.com/Hopkins-48955-Towed-Vehicle-Diodes/dp/B0002Q81Y4/ref=sr_1_3?keywords=one+way+diode&qid=1573226087&s=automotive&sr=1-3 This should work. Might also add this setup to the 317. Share this post Link to post Share on other sites
Pullstart 68,174 #9 Posted November 8, 2019 A simple inline one rated at whatever the headlight circuit is might be a cheaper solution if you have the means to soldier it in to the wiring circuit. Share this post Link to post Share on other sites
Mudrig150 353 #10 Posted November 8, 2019 (edited) 11 minutes ago, pullstart said: A simple inline one rated at whatever the headlight circuit is might be a cheaper solution if you have the means to soldier it in to the wiring circuit. The one I posted is an inline diode. It has 2 inputs and 2 outputs, and doesn't allow backfeeding. Plus it's a sealed diode. Edited November 8, 2019 by Mudrig150 Share this post Link to post Share on other sites
Pullstart 68,174 #11 Posted November 8, 2019 If it works for you, cool! Let us know how the project goes. Share this post Link to post Share on other sites
edgro 680 #12 Posted November 8, 2019 How about single throw, double pole,onoffon,work light on one side, 1pole, headlight other side both poles Share this post Link to post Share on other sites
Mudrig150 353 #13 Posted November 8, 2019 9 minutes ago, edgro said: How about single throw, double pole,onoffon,work light on one side, 1pole, headlight other side both poles How would that look? Share this post Link to post Share on other sites
edgro 680 #14 Posted November 19, 2019 this is what I was thinking Share this post Link to post Share on other sites
pfrederi 18,968 #15 Posted November 19, 2019 Get an LED work light wire it to the headlights ...yes it would be on all the time they are but the current draw is negligible relative to the head lights. Share this post Link to post Share on other sites
Mudrig150 353 #16 Posted November 19, 2019 17 minutes ago, pfrederi said: Get an LED work light wire it to the headlights ...yes it would be on all the time they are but the current draw is negligible relative to the head lights. That's not the issue. It's when I'm driving the tractor on the road, when I'll be blinding people behind me. Share this post Link to post Share on other sites
wallfish 18,625 #17 Posted November 19, 2019 My thought was just like edgro posted. Headlights only or both on at once in a single switch. Super easy to wire and it meets your demands. Share this post Link to post Share on other sites
