wildcatman01 0 #1 Posted April 20, 2009 Please forgive me I am new to this forum and I am looking for some technical information. I have a B-80 model wheelhorse and it runs like a scalded dog. i have recently been given a tiller attachment for a wheelhorse but i am not sure if it is the appropriate tiller for my model. I was wondering if anyone could tell me which model number will work. Also I was wondering, seeing as mine was not setup for a rear attachment, if any one could send me pictures of how to and which brackets and pulleys I will need to make it operational. Thanks for any help that you can give me. Tiller ID Tag: 07-30TL02-22706 2068 Share this post Link to post Share on other sites
zieg72 209 #2 Posted April 20, 2009 I just looked up the tiller and it appears that it may be for a 200 series from the look of it. May or may not work for your B-80 I just put one on my 520H and this forum helped me a lot to get what I needed. I hope I gave the right advice, but one thing is for sure, someone will correct me if I am mistaken. Good luck. Carl Share this post Link to post Share on other sites
zieg72 209 #3 Posted April 21, 2009 Scroll down to my link.... is a good resource for attachments available by model-year. Unfortunately it doesn't list a tiller for the B-80 maybe because of the HP. B-100's of the same year list a 7-1251 tiller. I don't know the B-series at all so physically it may work but the 8 hp. may not be enough to run it but my guess it should do fine. Share this post Link to post Share on other sites
kpinnc 14,641 #4 Posted April 21, 2009 I have a friend with an 856 and he uses it with a tiller. We have some really tough clay down here, so ANY tiller gets a good workout. He says his 8 hp Kohler will pull it, but says the tiller really pulls on the engine. Of course, low range WOULD be a good thing that he does not have on the 856, so I don't know how much that effects the setup. Kevin Share this post Link to post Share on other sites
zieg72 209 #5 Posted April 21, 2009 http://f1.grp.yahoofs.com/v1/kBrtScDmkIpjf...nge%201955-2000 should work now for the link. Share this post Link to post Share on other sites
wildcatman01 0 #6 Posted April 21, 2009 well how about a rear tach-o-matic setup my tractor has a uni-drive rear end with 8 speeds Share this post Link to post Share on other sites
zieg72 209 #7 Posted April 21, 2009 well how about a rear tach-o-matic setup my tractor has a uni-drive rear end with 8 speeds If you go to 1974 36" tiller and scroll over all the way to the right and it shows the current model with is the standard tiller just like the one on my 520H. 07-36TL05/79370 with a foot note. Mine is an older early 80's model. Mine has a slightly different idler pulley-belt tensioner arrangement but it works GREAT... Share this post Link to post Share on other sites
zieg72 209 #8 Posted April 21, 2009 Please forgive me I am new to this forum and I am looking for some technical information. I have a B-80 model wheelhorse and it runs like a scalded dog. i have recently been given a tiller attachment for a wheelhorse but i am not sure if it is the appropriate tiller for my model. I was wondering if anyone could tell me which model number will work. Also I was wondering, seeing as mine was not setup for a rear attachment, if any one could send me pictures of how to and which brackets and pulleys I will need to make it operational. Thanks for any help that you can give me. Tiller ID Tag: 07-30TL02-22706 2068 One more tidbit that I found out... By cross checking the tiller you have, it comes back to a 1982 B-85.... Maybe the 30" tiller is the right one after all for the 8 hp engine....???? I am done now trying to be helpful... Have a great evening... Share this post Link to post Share on other sites
Jim_M 179 #9 Posted April 21, 2009 You should have no trouble running a 30" tiller behind a B80-8. I have one ( 36")behind a 308-8. I run the engine wide open and put the tractor in low range and use 1st or second gear and have power to spare. You'll need a rear attachment hitch, it's the same one you use for a dozer blade. You'll also need the lift cable and rock shaft that goes under the seat and the idler/tensioner assembly. Share this post Link to post Share on other sites
wildcatman01 0 #10 Posted April 21, 2009 You'll need a rear attachment hitch, it's the same one you use for a dozer blade. You'll also need the lift cable and rock shaft that goes under the seat and the idler/tensioner assembly. ok then i just have the basic tractor with a mower deck that is grenaded so any ideas on where to get any of these parts or part numbers for them? And thank you to everyone for your help so far it has been helpful. Share this post Link to post Share on other sites
zieg72 209 #11 Posted April 21, 2009 http://www.wheelhorseforum.com/index.php?showtopic=9204 is what I recently went through. Post a picture of what you actually have and the group will help you out. I will donate the lift cable tube if you don't have one... Share this post Link to post Share on other sites
mcwh1950 2 #12 Posted April 21, 2009 first off read this topic http://www.wheelhorseforum.com/index.php?...t=0entry62104 member 4starcstms here on red square had one on a 1976 b80 , and he said it work good hope this help Share this post Link to post Share on other sites
mcwh1950 2 #13 Posted April 21, 2009 does you tiller look like this one this one is for vert engine. picture borrow for e-bay Share this post Link to post Share on other sites
kpinnc 14,641 #14 Posted April 21, 2009 this one is for vert engine. I was thinking the same thing Smitty. I've never seen a 30 inch tiller for a horizontal-shaft garden tractor like the B-80. BUT- It appears to connect (at least the belt, if you swapped the drive pulley around to the other side) the same way a 36 inch tiller does. I'm thinking getting it to work would not be difficult at all. If there are 30 inch tillers used on the smaller GTs, I apologize. As I said, I've just never seen them. Kevin 1 Share this post Link to post Share on other sites
mcwh1950 2 #15 Posted April 21, 2009 I was thinking the same thing Smitty. I've never seen a 30 inch tiller for a horizontal-shaft garden tractor like the B-80. BUT- It appears to connect (at least the belt, if you swapped the drive pulley around to the other side) the same way a 36 inch tiller does. I'm thinking getting it to work would not be difficult at all. If there are 30 inch tillers used on the smaller GTs, I apologize. As I said, I've just never seen them. Kevin the pulley for the 30" tiller are all on the left side. for 36 " tiller pulley are all on the right side. Share this post Link to post Share on other sites
wildcatman01 0 #16 Posted April 21, 2009 mcwh1950: my tiller does not match that one in your picture but however this is not my exact tiller, because i don't have a picture loaded but it is very similar to it and my pulley drive is on the right hand side. My setup would have to look like the setup from these pics. Now the only problem is tracking down the tensionor pulley and the rear attachment setup and the lift cable. http://www.wheelhorseforum.com/index.php?...t=0entry62104 Here is a pic of my rear diff not sure if the lift cable tube is there but take a look and let me know please Share this post Link to post Share on other sites
kpinnc 14,641 #17 Posted April 21, 2009 mcwh1950: my tiller does not match that one in your picture but however this is not my exact tiller, because i don't have a picture loaded but it is very similar to it and my pulley drive is on the right hand side. My setup would have to look like the setup from these pics. Now the only problem is tracking down the tensionor pulley and the rear attachment setup and the lift cable. http://www.wheelhorseforum.com/index.php?...t=0entry62104 Here is a pic of my rear diff not sure if the lift cable tube is there but take a look and let me know please If that is indeed the same "type" tiller as yours, then it will most definitely work with the pictured tractor rear end, providing you get the hitch. There are several on Ebay right now, and there usually are at any given time. Just be sure you get the right one. There were two types, and only one will work with the tiller/ long frame plow setup. The idler setup may be a bit harder to find, but can also be fabricated pretty easy. The lift cable is still available from Toro. Because your tractor has the newer style fender pan support, you'll also need the rock shaft/ bell crank that goes in the back. Again, they come up fairly often for sale online and are easily fabricated. Not trying to create more questions than answers for you. The good news is that your tiller will work with your tractor. Now you just need a few of the smaller parts to put it all together. If you find something that your aren't sure will work with your setup (hitch, cable, idler, etc...), just post it here and we can try to help you decide on the right parts. Or, you can look on Toro.com with your tiller model number and find the parts listing. The pics there will also be helpful in your search. Good luck! Kevin Share this post Link to post Share on other sites
wildcatman01 0 #18 Posted April 21, 2009 The idler setup may be a bit harder to find, but can also be fabricated pretty easy. The lift cable is still available from Toro. Because your tractor has the newer style fender pan support, you'll also need the rock shaft/ bell crank that goes in the back. Again, they come up fairly often for sale online and are easily fabricated. here is an ebay link for a rocker shaft will this one work for my B-80 model? http://cgi.ebay.com/wheel-horse-C-160-gard...3%3A11|294%3A50 Share this post Link to post Share on other sites
C-Series14 15 #19 Posted April 21, 2009 No, that is for the tractor's mid lift mechanism... Share this post Link to post Share on other sites
KyBlue 655 #21 Posted April 22, 2009 Okay lets see if I can help a bit... heres some photos of the tiller, the Idler Setup, and mounted... And since Last year I didnt have all the parts needed... (still used it anyway, just a PITA to lift) I dont have photo fo the rockshaft... But Here is one installed on a similar WH Hope this helps! Share this post Link to post Share on other sites
wildcatman01 0 #22 Posted April 22, 2009 Thank you them pics helped a lot. Now any ideas on where i might be able to find the mid mount idler setup? Ive located the rear rocker shaft adn the rear mount but i am not having any luck with the idler pulley Share this post Link to post Share on other sites
Jim_M 179 #23 Posted April 22, 2009 Somebody makes a nice copy of it, but I can't remember who it is right now. He sells them on eBay every so often. Share this post Link to post Share on other sites
KyBlue 655 #24 Posted April 23, 2009 There is a Feller on the Yahoo groups that does em. You can still buy the pullies, and just have to make the metal parts.. Share this post Link to post Share on other sites
kajamo240 3 #25 Posted April 22, 2012 4StarCstms, What size belt is that? Share this post Link to post Share on other sites
