chev0545 236 #1 Posted November 1, 2019 anybody know model # 79350 blade fit thanks 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,757 #2 Posted November 1, 2019 79350 is the 2nd from the last. The 520 models with foward-swept front axle require an extension kit. Dozer DNA of long tractor frame dozer blades 1966-1967 model BD-426 - Fits LONG frame tractors - Mounts ahead of the rear axle - replaced by 1968 model 6-1111 - Fits LONG frame tractors - Mounts ahead of the rear axle ---------------------------------------------------------------------------------------------------------------------- 1968 model 6-4111 - First to fit LONG & SHORT frame tractors and first to mount under the rear axle - replaced by 1969 model [6-4112 + 6-9621] 1970-73 model [6-4113 + 6-9622] 1973-74 model [6-4113 + 6-9623] 1974 model [6-4114 + 6-9624] 1974 model 6-2131 1975 model 6-2132 1976 model 6-2133 1976 model 66-42BC01 1977 model 76-42BC01 1978 model 86-42BC01 1979 model 96-42BC01 1980 model 06-42BC01 1981-1984 model 06-42BC02 (Up to here they are 42" wide) 1984-1989 model 06-48BC01 (They are now 48" wide) - replaced by the following 1990 model 06-48BC02 1991-1993 model 06-48BC03 1993-2001 model 79350 - (105-1502 kit adapts 2001 and older GT Classic-Series blades to fit 2002 and later tractors 2002 2004-2009 2012 model 79364 - (105-1501 kit adapts 79364 blade to fit 2001 and older GT Classic-Series) Answer your question? Garry 2 1 Share this post Link to post Share on other sites
Ed Kennell 43,153 #3 Posted November 1, 2019 (edited) #79350 will fit long and short frame tractors. 520 with forward swept axle will require a frame extension kit. The blade angle lever may need to be modified to clear the foot rests on some tractors. A under axle bracket is required. OOPs, Garry has all the info. Edited November 1, 2019 by Ed Kennell 3 1 Share this post Link to post Share on other sites
