gt14rider 1,275 #1 Posted October 31, 2019 Hi all, can't seem to find a ign switch for my 1970 gt14, it is converted to coil, points. 101876 should be i ign, 5 terminal, 4 position switch,with a 9/16 thread, but all that comes up are magneto ign switches. I have a 3 position switch that's been working, but orginal was 4 position. Think it's a little more heavy duty. Anyone have a good p/n Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,417 #2 Posted October 31, 2019 I think this one should work as long as you have a starter solenoid. The 101876 is no longer available. Click on the picture for more. Garry Share this post Link to post Share on other sites
953 nut 68,162 #3 Posted October 31, 2019 The four position switch prevented the PTO from being turned on unless the ignition switch was moved to the proper position. To me that was an unnecessary inconvenience. The switch that came on the GT-14 was not heavy duty and if it is working for you the three position switch should be fine. 1 1 Share this post Link to post Share on other sites
gt14rider 1,275 #4 Posted October 31, 2019 Thanks for the info, don't have a electric clutch so no need for 4 position, 3 position is working fine, thanks again. 1 Share this post Link to post Share on other sites
