Retired Wrencher 6,078 #1 Posted October 30, 2019 I won some $$ in the poker room so decided to get this. It is over 12". I was going to make one but! last piece that I needed for the plow. I like the welded stud. Makes it easy to put on. 4 5 1 Share this post Link to post Share on other sites
stevasaurus 23,466 #2 Posted October 30, 2019 If you notice..the hair pins are at different angles. It does make a difference which one is up and which one is down for ease of placing those hair pins. 3 Share this post Link to post Share on other sites
ebinmaine 74,709 #3 Posted October 30, 2019 1 hour ago, stevasaurus said: If you notice..the hair pins are at different angles. It does make a difference which one is up and which one is down for ease of placing those hair pins. Valid point for mr. Steve asaurus. I've found that the lower one makes nearly no difference on angle but trying to get your hand in the top under the hood stand with the pin going the wrong direction can be a nightmare. keeping in mind I'm not exactly a small person and that is definitely a small space. 1 Share this post Link to post Share on other sites
Retired Wrencher 6,078 #4 Posted October 31, 2019 (edited) 13 hours ago, stevasaurus said: If you notice..the hair pins are at different angles. It does make a difference which one is up and which one is down for ease of placing those hair pins. Thanks Steve for that info. I will have to check that out. Edited October 31, 2019 by Retierd Wrencher Share this post Link to post Share on other sites
Retired Wrencher 6,078 #5 Posted October 31, 2019 12 hours ago, ebinmaine said: Valid point for mr. Steve asaurus. I've found that the lower one makes nearly no difference on angle but trying to get your hand in the top under the hood stand with the pin going the wrong direction can be a nightmare. keeping in mind I'm not exactly a small person and that is definitely a small space. I will have to look at that Eric and see what is the best way to install the cotter pin. I am like you Big hands. May be meddle nose vice grips? Share this post Link to post Share on other sites
ebinmaine 74,709 #6 Posted October 31, 2019 1 hour ago, Retierd Wrencher said: I will have to look at that Eric and see what is the best way to install the cotter pin. I am like you Big hands. May be meddle nose vice grips? you'll be able to get in there okay but you'll find it's a lot easier from one angle or another so figure out which way works best and maybe Mark the top of the link? Share this post Link to post Share on other sites
Retired Wrencher 6,078 #7 Posted November 1, 2019 22 hours ago, ebinmaine said: you'll be able to get in there okay but you'll find it's a lot easier from one angle or another so figure out which way works best and maybe Mark the top of the link? Will do Eric. I do like the welded pin. I think some one for this forum makes these? 1 Share this post Link to post Share on other sites
