Countdown To Christmas!
adsm08
Bad Vibrations
adsm08
So while mowing tonight the 855 suddenly got a nasty vibration. When I bought it it seemed pretty smooth, especially for an old tractor, a month or so ago it started with a little vibration, nothing worrisome, and really only felt in the foot rests. Tonight while I was mowing it got worse all of a sudden. I still only feel it in the foot rests, but now it is like standing on one of those shiatsu massage machines. At first, when it started I stopped and checked the oil, which was a bit low, so I topped it up, and the vibration went away for a while, but came back.
Any ideas where I should start looking? I'm going to bring my timing light home tomorrow and check that.
lynnmor
Start by eliminating the mower deck.
  • Like 4
adsm08
Forgot, did that. When I shut the PTO off the vibration does not change. In gear or out of gear, moving or sitting still don't seem to matter either.
Throttle seems to make the biggest difference, but doesn't eliminate it.
ZXT
Loose engine mounting bolts?
  • Like 4
troutbum70
I would agree on the loose engine mounting bolts or a couple broken ones. Does that engine sit on rubber?
SylvanLakeWH
:text-yeahthat: to start. Then go around tractor tightening bolts as you go...
Any sheet metal humming? I had the foot rest bolt loosen up on me and the vibration was amazing...
lynnmor
Loose flywheel?  Broken magnets in flywheel?
Lee1977
I would check the drive belt for a piece missing or loose pulleys. It could also be a bad bearing on the input shaft of the transmission.
stevasaurus
No, no rubber under engine mount.
   You just have vibration...no strange noises??
adsm08
I got to checking it here a few minutes ago. Like Stevasaurus said, no rubber, my block/pan is bolted right to the frame. I did grab the engine and shook it, which rocked the whole tractor, and helped me notice the large bolts that hold the drive belt guard to the engine was gone, and letting the guard flop and ride on the back side of the belt.
I fixed that and ran it for a few minutes, it was nice and smooth like I remember it being, but I didn't run it real long, so I guess time will tell.
stevasaurus
I think you found it!!  Wouldn't hurt to just look it all over to see if anything else has worked loose.  Nice that this was a simple fix.  :orcs-cheers:
adsm08
I hope so. I'm going to give it a more thorough look-over before I use it again, but I'm down to only mowing about once every other week, so it may be a bit.
adsm08
Well fixing the belt guard made it much better, but did not fix it altogether. It has been tolerable, so I haven't been worrying about it much.
Today while mowing the PTO tension spring fell off the tractor. The cotter pin that holds the spring to the pedal arm tore. While fixing that I noticed a crack in the frame rail just about even with the PTO pedal. After cleaning it up I found the spot has been welded previously as there is a bead already there.
I'm gonna have to tear into it pretty good to be sure, or even to get at it to fix it. In the mean time I think my dad has a spare 32 or 36 inch deck and mule drive for his 310-8 that I am going to try to rig up to the 800S. I'm told it can be done. The guy I bought the 800 from hinted at, without coming right out and saying that he had this tractor in that configuration at some point in the past.
  • Similar Content
    • MainelyWheelhorse
      By MainelyWheelhorse
      Hey guys, what do you do about the vibration from the engine. Was there something in place from the factory that combatted it? Both my 308 and 312 have significant vibration when the engine is running. It’s almost like something is slightly unbalanced. I have looked at anti vibration pads, and checked the mounts to see if it was supposed to have some sort of dampening. Thanks!
    • Hodge71
      By Hodge71
      Not the Beach Boys by any means but I can say that this thing vibrates worse than an old panhead Harley with a fouled plug. Now I have never owned a 14 Kohler but I have a 12 and a 16 and this is much worse than both. I was told possibly rebuilt with no balance gears? Anyone.....Anyone?.... Also have pictures and questions on the year of this engine. It has an odd flywheel screen. Different than the 12 and 16 as well. It has a box hanging off the side of the engine that my 12 and 16 don't have. Also Im having electrical trouble. The headlights don't work, the electric clutch doesn't work and the battery only seems to be receiving 13.4 volts at full throttle. Is that enough to charge the battery or are there electrical issues I need to figure out? I know my 12 and 16 both have 13.9 or 14.1VDC respectively. The 416 Onan I built for my Dad had 17VDC but it was a bad voltage regulator and its now happy at 14.5 VDC...So whats the scoop on this thing? Any engine gurus have an idea?
