pfrederi 20,659 #1 Posted October 21, 2019 Inflated a couple of very old 6.00x12 so i could stick them on my Electro16 project making it easier to roll around and not take as much room as normal turfs. Inflated them to about 15 psi left them on the floor and about 15 minutes later one went bang. Side wall and tube failure . Guess the sunshine in the window raised tire pressure a bit too much. 2 3 Share this post Link to post Share on other sites
Wishin4a416 2,594 #2 Posted October 21, 2019 Bummer. I had that happen with a boat trailer tire last year. Aired it up and 5 minutes later kaboom. Share this post Link to post Share on other sites
JCM 11,165 #3 Posted October 21, 2019 (edited) After that BANG did you guys have to change your.............. well you know what. Edited October 21, 2019 by JCM 3 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #4 Posted October 21, 2019 Ill bet you thought it was horse rustlers !!! Share this post Link to post Share on other sites
Stormin 9,988 #5 Posted October 21, 2019 Some expanding foam will sort that. Share this post Link to post Share on other sites
Pollack Pete 2,273 #6 Posted October 21, 2019 Old,dry-rotted tires equals one loud noise.Been there,done that.One reason I love new tires. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #7 Posted October 21, 2019 Need to get you a set of these Share this post Link to post Share on other sites
Stepney 2,357 #8 Posted October 21, 2019 Too bad considering we can't really get 6-12's anymore.. Dangit, thought I had the only Electro 16! Share this post Link to post Share on other sites
pfrederi 20,659 #9 Posted October 21, 2019 6 minutes ago, Stepney said: Too bad considering we can't really get 6-12's anymore.. Dangit, thought I had the only Electro 16! This will be my second Electro 16 Number one will shortly be waking up from her long summer nap.... 1 Share this post Link to post Share on other sites
ZXT 2,402 #10 Posted October 21, 2019 Aren't the tires only rated for 12 PSI anyways? I always run below that because I'm afraid they won't handle it. 15 seems a bit much. Share this post Link to post Share on other sites
richmondred01 2,372 #11 Posted October 21, 2019 Mine just got up too. Doesn’t see too much work down here. 1 Share this post Link to post Share on other sites
JimmyJam 542 #12 Posted October 21, 2019 Off the top of my head I can’t remember the actual PSI of WH tires. Are rears different than fronts? Share this post Link to post Share on other sites
Stormin 9,988 #13 Posted October 21, 2019 4 minutes ago, ZXT said: Aren't the tires only rated for 12 PSI anyways? I always run below that because I'm afraid they won't handle it. 15 seems a bit much. 12psi is the recommended pressure for use. Helps grip on grass. Harder and the tyres can slip. 1 Share this post Link to post Share on other sites
Herder 2,356 #14 Posted October 21, 2019 2 hours ago, pfrederi said: Inflated a couple of very old 6.00x12 so i could stick them on my Electro16 project making it easier to roll around and not take as much room as normal turfs. Inflated them to about 15 psi left them on the floor and about 15 minutes later one went bang. Side wall and tube failure . Guess the sunshine in the window raised tire pressure a bit too much. Blew the dust out of the rafters! Hope you didn't $#!# yourself. 1 Share this post Link to post Share on other sites
clueless 3,403 #15 Posted October 21, 2019 Far better for it to go kaboom 15 minutes later than when your filling it . Hey, let's be careful out there. 1 Share this post Link to post Share on other sites
