nyhorseman 7 #1 Posted October 16, 2019 Broke the belt on my A-51, what was on it was one belt that ran from engine pulley through all the pulleys on the deck.. however, after looking at the manual on here, it seems that it should have 2 belts. one from the engine pully to deck drive and another from the deck drive to the blade pulleys. Is this correct? (sorry if my terminology is incorrect) Share this post Link to post Share on other sites
WHX?? 54,995 #2 Posted October 16, 2019 My A-81 has only one deck drive belt and I have the 32 inch deck. Yours should be the same. There is a second belt from the engine to the transmission tho. Maybe what's you are seeing in the manual. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #3 Posted October 16, 2019 Do you have any models numbers for the tractor and deck? Looks like the A-81 and A-111 use different belts or perhaps decks than the A-51. See no double belts for the A-51 but the 36" decks for the A-81 and A-111 yes. This is a 32" side discharge deck? Garry Share this post Link to post Share on other sites
nyhorseman 7 #4 Posted October 17, 2019 14 hours ago, WHX24 said: My A-81 has only one deck drive belt and I have the 32 inch deck. Yours should be the same. There is a second belt from the engine to the transmission tho. Maybe what's you are seeing in the manual. Thanks WHX24, that's what I was hoping to hear. I knew the A51 & 81 were similar and was hoping someone here had one ...I have a 32 inch deck as well, any suggestions where to purchase a replacement belt? Share this post Link to post Share on other sites
