SaintJay 9 #1 Posted October 15, 2019 Sorry if this info has been previously posted, I couldn't find it. I am looking for the part number for a C-165 drive belt. Thanks, Jay Share this post Link to post Share on other sites
JCM 10,525 #2 Posted October 15, 2019 Should be # 7473 Toro 2 Share this post Link to post Share on other sites
pfrederi 19,520 #3 Posted October 15, 2019 Is this an 8 speed or an auto different belt #s Also some were sundstrands some Eatons. Share this post Link to post Share on other sites
SaintJay 9 #4 Posted October 17, 2019 It is an 8 speed. Share this post Link to post Share on other sites
peter lena 9,655 #6 Posted October 18, 2019 while you are at it, in replacing that belt, take the time to LUBRICATE ALL RELATED MOVEMENT POINTS , i am amazed to see pictures of problem areas , with the rust a stain coming from a movement point, really, you don,t see that ? on my last belt replacement , checking the entire vari drive set up , i replaced the rear spring tension pulley, the one that works off the clutch pedal. found a duplicate size , with A MUCH LARGER BEARING WITH A 3/8 CENTER for a perfect fit , result , was super slick and smooth clutch engagement. there are many areas in these tractors that you can , improve with some , want to make it easier point of view. this is jmoo, , good luck with it , pete , Share this post Link to post Share on other sites
SaintJay 9 #7 Posted November 11, 2019 the 7473 is 5/8" x 82" right? This is what I got but it seems to be too wide. This is driving me crazy. Thanks to all who took the time to answer. I appreciate the help. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,932 #8 Posted November 11, 2019 I usually use Gates green belts which are listed as slightly wider at 21/32" and they work fine. What is the problem? Garry Share this post Link to post Share on other sites
