Burnerman 759 #1 Posted October 14, 2019 Are the front spindles 3/4” or smaller? 72 Commando 800 with a Kohler. Share this post Link to post Share on other sites
Burnerman 759 #3 Posted October 14, 2019 Thanks! This tractor thing is starting to get out of hand. As soon as my son gets home with the trailer this will be the next project. 😁 1 Share this post Link to post Share on other sites
wallfish 20,576 #4 Posted October 15, 2019 2 hours ago, Burnerman said: This tractor thing is starting to get out of hand. There's certainly worse things we could be doing so don't fret over how many it gets up to. You'll find the comfort zone. 1 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #5 Posted October 15, 2019 If that is the original deck it has double d spindles and blades. Share this post Link to post Share on other sites
troutbum70 858 #6 Posted October 15, 2019 I can measure mine tomorrow and report back. Share this post Link to post Share on other sites
Burnerman 759 #7 Posted October 15, 2019 6 hours ago, troutbum63 said: I can measure mine tomorrow and report back. No need sir! I had another set of rims that I was going to bring with us to make it easier to load onto the trailer but was not required. 7 hours ago, elcamino/wheelhorse said: If that is the original deck it has double d spindles and blades. I haven’t gotten the deck off yet but I do believe it’s the original deck. Share this post Link to post Share on other sites
redone 45 #8 Posted October 17, 2019 Ok guys. Another issue with onan 20 hp onan performer 20 xls. Starts good. From idel to higher rpm 3000 runs high then drops. Up and down rpm. Raise to higher speed it comes of it, but better. Adjusted only jet on side of carb no differance. Is this an easy fix? Thanks Bill Share this post Link to post Share on other sites
pfrederi 21,145 #9 Posted October 17, 2019 4 minutes ago, redone said: Ok guys. Another issue with onan 20 hp onan performer 20 xls. Starts good. From idel to higher rpm 3000 runs high then drops. Up and down rpm. Raise to higher speed it comes of it, but better. Adjusted only jet on side of carb no differance. Is this an easy fix? Thanks Bill you may get more help if you make this a new topic as you problem has no relation to the original post Share this post Link to post Share on other sites
