Bill D 2,308 #1 Posted October 12, 2019 Does anyone have a schematic for a 314-8 Model 2114K801 S/N 10587? I had one like it that I parted and I used the harness in another tractor. It was simple and easy to adapt for various engines. I would like to copy it for rewiring another tractor. Thanks. Bill Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,561 #2 Posted October 12, 2019 Garry 1 Share this post Link to post Share on other sites
953 nut 60,714 #3 Posted October 12, 2019 If this is the tractor you plan to put the "K" engine in there will need to be some changes in the charging system wiring. Most K series engines will have a 15 amp regulated charging system whereas the diagram you requested has the 3 amp unregulated with AC power to the lighting. Take a look at the replacement engine and tell us what charging system it has. Share this post Link to post Share on other sites
Bill D 2,308 #4 Posted October 12, 2019 Thanks for the diagram. I already used this harness to install a KT17 in place of the K321 I had that had a rod knock so I am familiar with the wiring issues related to the charging system. Thanks again. Bill 1 Share this post Link to post Share on other sites
