ronhatch 410 #1 Posted October 6, 2019 Because I always worried about the 50+ year old diaphragm leaking gas into the crankcase on my 867 w/ a K181, I removed the fuel pump and replaced it with a nice home made 1/8" thick aluminum cover. The gas now flows using gravity only. My question is; Should I vent the crankcase by drilling a hole in my new aluminium cover plate and installing a hose fitting and running a hose to the backside of the air cleaner housing? Or better yet, installing a simple 'pull out' dipstick and let it vent through that and doing away with the PITA screw in type? Share this post Link to post Share on other sites
pfrederi 19,289 #2 Posted October 6, 2019 Crankcase is vented the cover and flapper valve over the valve chamber. 1 1 Share this post Link to post Share on other sites
