paul lemelin 0 #1 Posted October 4, 2019 I have a model 6785 Blu Max 11 hp 4 stroke gas engine that is about two years old. I can't find out anything about parts, diagrams or anything else, The magnet inside the shtoud which is fastened to the block snaped. Its held on by one philiips screw. Engine was running fine till then. Are there any crossover parts/ Any help would be appreciated. Thanks Paul Lemelin Hamilton Mass. Share this post Link to post Share on other sites
pfrederi 19,794 #2 Posted October 4, 2019 Looks like a cheap Chinese copy of a Honda... like the powermax, predator and any other number of names. Repair by replacement. Share this post Link to post Share on other sites
pfrederi 19,794 #4 Posted October 4, 2019 I found 3 reviews one liked it two hated it one had failure after 2 days the other couldn't find any parts. You may find that some predator parts may work but it would be a gamble. Share this post Link to post Share on other sites
ebinmaine 77,079 #5 Posted October 4, 2019 2 hours ago, pfrederi said: Repair by replacement 2 hours ago, paul lemelin said: Any help would be appreciated. Thanks Paul My honey and I try to repair as much as we can around our place. Sometimes you trip over something that is really just not meant to be fixed, but replaced. You may be able to make the part that you need. You may be able to check with your local small engine repair places it's definitely disappointing when you have something like that that works otherwise and you can't find that one simple little part but in this case I probably would agree with Paul above. Repair by replacement. 1 Share this post Link to post Share on other sites
