The Tuul Crib
Crank catches
The Tuul Crib
 I have this K1 81 that is driving me crazy. I turn the crank and it feels like  something stops it and then you can turn it and it stops it again.  I pulled the oil pan and looked inside and cannot see anything out of the ordinary. Any ideas what does could be ?
AMC RULES
Pull the head...
are the valves sticking?
The Tuul Crib
10 minutes ago, AMC RULES said:
Pull the head...
I pulled ahead don't see any obstructions there. I pull the pan off and looked inside
 And could not see anything there. I am kind of baffled of what it could be. When you turn the crank it will stop and then you can turn it some more and it will turn again and then stop .
adsm08
Does it still do it with the head off?
wallfish
Just guessing but if you have the head and oil pan off and don't see anything obvious, maybe something in the crank to cam gears or a broken gear tooth?
WHX??
Where does it hang up Cribs, compression, exhaust, power stroke?
The Tuul Crib
Im not finding any broken teeth on the
gears. It kind of feels almost like its dry inside if that makes sense.You turn the crank a little bit and then hit friction and then turn it past that point and then friction again. When l get more time ill go in to
in more detail.
pacer
With the recent post on flywheel magnets --- maybe one got a piece broke off and is dragging ------- nah! more I think about it that would just lock it up completely . Hmmmmm......
The Tuul Crib
 Well this is off the same motor. What's funny is I just picked up another 12 horse pulled off the fly wheel on it and all the magnets were stuck to the stater. I make sure to Mark those before I pulled them
off!
gt14rider
Check the cam, had similar problem on my k181, cam or pin was bent, swapped out with a different cam and pin fixed it.
Shynon
Pull the rod cap off and see if the rod has spun on the crank
WHX??
:text-yeahthat:You got the pan off you always pop off the big end for inspection and a few dims Cribs.
953 nut
When you rotate the crank shaft are you seeing the valves open and close?   Could be a broken cam shaft.
The Tuul Crib
Valves are moving fine . I hoping not to
tare this one down. Its possible that it could be a sticky valve.
Mudrig150
How far does it turn before it meets friction? That'll help narrow it down.
The Tuul Crib
  About a quarter of a turn
Mudrig150
So every 90 degrees?
Edited by Mudrig150
The Tuul Crib
Yes
Mudrig150
Something is probably wrong with the cylinder walls or the crank. Pull the rod cap and see how it looks.
bc.gold
1 minute ago, The Tool Crib said:
Yes
Then its not cam or valve train related.
The Tuul Crib
I'm going to pull the rod cap When I get home and see what's going on with the crankshaft first and then go from there.
The Tuul Crib
 OK so I got home flipped  the motor over took the rod cap off and pulled the piston out. Problem solved the crank turns freely once again. Now. Looking in the cylinder I can still see the crosshatches. The piston is  stamped STD.  My thought is to hone it out a little put new rings in it and I'm good to go
AMC RULES
So, is the bore out of round?
The Tuul Crib
Not sure.  I pulled the rings off the piston and it moved freely inside the cylinder.
bc.gold
Are the ring lands free of carbon.
