Stepney 2,354 #1 Posted September 28, 2019 Hello, all. I have an 80s 42SD on my WorkHorse at the moment. Just went all through it. Still has the original WH wheels on it. Set the deck lever, etc. But even with the deck all the way lifted, it only seems to cut at about 2 1/4" which is just way too low for our yard. Setting it lower will drop the deck right onto the ground.. Would it hurt anything if I just stuck some larger wheels on? I can't seem to find any other way of getting it to cut higher, tough the adverts claimed it could cut up to 3". 1 Share this post Link to post Share on other sites
Tractorhead 9,212 #2 Posted September 28, 2019 (edited) bigger wheels will do the trick on your Setup or Wheels with bigger diameter (AS) i had similar problems, especial on some slope within the yard or when i have to mow arround the House. Especially after i inserted the Hydraulicpump, the lever cannot lifted fully, just one click before max, otherwise it scraps on Pump Pulley. But that was an issue, i seen before my rework and i ignored that. I investigate that later a bit closer and found out, that for my issue i just can extend the liftheight with bigger Tyres at all. Maybe a grinding or reworking on levers can also do the trick, but unfortunately i loosing once stability, or the Mowerdeck grinding sometimes onto Pulley’s, what is a nogo for me. So the Ground clearance at all increases easiest, by using bigger Tyres and i have more gap to lift or drop. After increasing ground clearance, a bit bigger Wheels on mowerdeck can also be used to keep the cut higher. For the moment i just dealin with a deeper (lower) mowing, (Mowerdeck on middle) because other Tyres depends on other Rim‘s they seems to big to fit between mowerdeck and rearaxle. The gap i have between Axle and Mowerdeck ain‘t fit with bigger Wheels on my Tractor. Edited September 28, 2019 by Tractorhead 1 Share this post Link to post Share on other sites
SylvanLakeWH 28,483 #3 Posted September 28, 2019 Same issue with mine... Make sure your adjustment knob is all the way up... Larger tires will help but need to raise all roughly the same or you will risk scalping from angled deck. Share this post Link to post Share on other sites
pfrederi 18,698 #4 Posted September 28, 2019 I have used larger deck wheels. just remember to relevel the deck front to back. You want the front about 1/8" lower than the back. 2 Share this post Link to post Share on other sites
peter lena 9,281 #5 Posted September 28, 2019 been using these on my decks ,https://www.tractorsupply.com/tsc/product/martin-wheel-6x1-3-8-plastic-deck-wheel-1-2-in-bushing-1-3-8-in-offset-hub-1128205?cm_mmc=feed-_-GoogleShopping-_-Product-_-1128205&gclid=CjwKCAjwibzsBRAMEiwA1pHZriPozGClhNbK05_CVvbvYsX03z1mvjxkn1AHYMg9sw0n4cGCf5ouohoCpu0QAvD_BwE , no issues. having a clean deck, and sharp blades ,along with a top height ,will always give you a good looking cut, i also regularly tow a steel spiker when cutting , punching thousands of holes in my lawn. i now use grub killer 2 times a year, no more grubs or moles ! i never cut the grass the same way , always giving it a break to over grow old seams, as long as you cut over your previous line it looks great. when i see a commercial cutter go from grass to dirt , it just does not make any sense , pete Share this post Link to post Share on other sites
