huey 7 #1 Posted September 22, 2019 Just wondering if all the wide base oil pans are same depth? I have a kohler magnum wide base 10hp that came off a wheel horse that bolts from under the frame and wondering if it would fit a 16hp magnum wide base that doesn't have the bolt holes threaded in the bottom, just from looking they look the same? Share this post Link to post Share on other sites
oliver2-44 10,976 #2 Posted September 22, 2019 Both wide and narrow base oil pans come in several depths. You will need to measure the depth of each one. However, engines with a shallower pan have the oil dipper on the bottom of the connecting rod cut shorter If the 16hp has a deeper pan, you can trim the oil dipper to fit your shorter pan. 1 Share this post Link to post Share on other sites
Lee1977 7,384 #3 Posted September 25, 2019 Kohler standardized the crankshaft height on K-series 10 HP trough !6 HP wide base engines when they came out with the K-Series. I would think the Magnum Series wide block would all the the same .height also at 6" from base to center of crankshaft same as the K-series. I just measured my 12 HP magnum and it's 6" 1 Share this post Link to post Share on other sites
