grnlark 492 #1 Posted September 18, 2019 The Wisconsin engine on my Senior dates to Sept 1954. It has the correct cast iron Zenith carb on it. I want to get a carb rebuild kit and have been told its a model 61/161 Zenith. Can anyone confirm that? Thanks in advance, Matt Share this post Link to post Share on other sites
J854D 145 #2 Posted September 18, 2019 The model number for your Zenith carburetor is on that round disc with the rivet in the middle on the top of the carb. I can see the disc in your photo. Carefully remove the paint & the carb number is there! -JD- 3 Share this post Link to post Share on other sites
grnlark 492 #3 Posted September 18, 2019 9 hours ago, J854D said: The model number for your Zenith carburetor is on that round disc with the rivet in the middle on the top of the carb. I can see the disc in your photo. Carefully remove the paint & the carb number is there! -JD- You're absolutely right. Thank you! Very much appreciated. 1 Share this post Link to post Share on other sites
J854D 145 #4 Posted September 19, 2019 No problem! I used to see a lot of old Zenith & Marvel-Schebler carbs at the parts store/machine shop where I used to work. If memory serves me, the carb number is the number closest to the rivet (11595). You should be able to order a repair kit using that number. Great photos of the tag! -JD- 2 Share this post Link to post Share on other sites
J854D 145 #5 Posted September 19, 2019 P.S.- I believe the L48AD number on the tag is a Wisconsin part number for the carburetor. Hope that helps! -JD- 1 Share this post Link to post Share on other sites
