Lonnie 35 #1 Posted September 18, 2019 Good Day to all. Does anyone know where I can get a owner, service, parts and repair parts manual for a 1962 model 552 .thank You for your time. Share this post Link to post Share on other sites
wallfish 20,033 #2 Posted September 18, 2019 (edited) Edited September 18, 2019 by wallfish 1 Share this post Link to post Share on other sites
oliver2-44 11,526 #3 Posted September 18, 2019 lots of friendly helpful members here. 1 Share this post Link to post Share on other sites
rjg854 13,075 #4 Posted September 18, 2019 @Lonnie did you get what you needed? Share this post Link to post Share on other sites
953 nut 66,569 #5 Posted September 18, 2019 9 hours ago, Lonnie said: Good Day to all. Does anyone know where I can get a owner, service, parts and repair parts manual for a 1962 model 552 .thank You for your time. There isn't a service manual for your but we do have service manuals for the engine and the transmission if you need them. There are also a lot of good informational threads on this site covering various aspects of repair and restoration. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,276 #6 Posted September 18, 2019 2 pages of results with a 552 search https://www.wheelhorseforum.com/search/?&q=552&type=downloads_file&search_and_or=or Garry 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #7 Posted September 18, 2019 Looks like everyone above has you covered! The best tractor Site on the planet! We call it and 1 Share this post Link to post Share on other sites
Lonnie 35 #9 Posted September 18, 2019 4 hours ago, 953 nut said: There isn't a service manual for your but we do have service manuals for the engine and the transmission if you need them. There are also a lot of good informational threads on this site covering various aspects of repair and restoration. 3 Share this post Link to post Share on other sites
953 nut 66,569 #10 Posted September 18, 2019 Looks like a very complete nicely maintained . Don't think I would change a thing. Share this post Link to post Share on other sites
wallfish 20,033 #11 Posted September 18, 2019 The engine has been upgraded to a Kohler which appears to be an 8hp K181 but it could be a 7hp. The number is on the engine plate. That's the engine manual you will need The original engine for a 552 would have been a 5.5 hp Tecumseh/Lauson 1 Share this post Link to post Share on other sites
WHX?? 56,847 #12 Posted September 18, 2019 but what 'Fish is sayin might be a good thing.. & 1 Share this post Link to post Share on other sites
Lonnie 35 #13 Posted September 19, 2019 15 hours ago, rjg854 said: @Lonnie did you get what you needed? Thank you , the motor is supposed to run but I don’t want to try it until I find and buy the glass bulb that holds the gas. One on it looks like has calcium or something in it. Share this post Link to post Share on other sites
953 nut 66,569 #14 Posted September 19, 2019 10 hours ago, Lonnie said: glass bulb that holds the gas. One on it looks like has calcium or something in it. You could probably get it cleaned up with a household product like CLR or anything with Phosphoric Acid in it, Share this post Link to post Share on other sites
WHX?? 56,847 #15 Posted September 19, 2019 18 hours ago, Lonnie said: glass bulb that holds the gas That would be a sediment bowl. You can try and clean it but seldom do they come apart and go back together with out leaking. You can get just the glass and gasket separate but often best to just get a whole new one. I would recommend an inline filter and new gas lines as well. https://www.ebay.com/itm/SEDIMENT-BOWL-FUEL-FILTER-BRIGGS-KOHLER-PART-393169-690612/201297119434?epid=2046087788&hash=item2ede3e48ca:g:9-wAAOSwBahU8TNg 1 Share this post Link to post Share on other sites
Lonnie 35 #16 Posted September 19, 2019 4 hours ago, WHX24 said: That would be a sediment bowl. You can try and clean it but seldom do they come apart and go back together with out leaking. You can get just the glass and gasket separate but often best to just get a whole new one. I would recommend an inline filter and new gas lines as well. https://www.ebay.com/itm/SEDIMENT-BOWL-FUEL-FILTER-BRIGGS-KOHLER-PART-393169-690612/201297119434?epid=2046087788&hash=item2ede3e48ca:g:9-wAAOSwBahU8TNg Thank you very much , will order it , do you know what in-line filter and gas line I need? Thanks for being so kind with me as I know nothing. Share this post Link to post Share on other sites
Lonnie 35 #17 Posted September 19, 2019 4 hours ago, WHX24 said: That would be a sediment bowl. You can try and clean it but seldom do they come apart and go back together with out leaking. You can get just the glass and gasket separate but often best to just get a whole new one. I would recommend an inline filter and new gas lines as well. https://www.ebay.com/itm/SEDIMENT-BOWL-FUEL-FILTER-BRIGGS-KOHLER-PART-393169-690612/201297119434?epid=2046087788&hash=item2ede3e48ca:g:9-wAAOSwBahU8TNg I ordered what you sent me on eBay Share this post Link to post Share on other sites
WHX?? 56,847 #18 Posted September 20, 2019 No problem on knowing nothing Lonnie. I have been into for many years and still know nothing but lean heavily on the crew here to educate me! You will need a length of standard 1/4 fuel line and a off the shelf filter that is very common. If one of the other fellas would kindly post a to their favorite filter please do. 1 Share this post Link to post Share on other sites
953 nut 66,569 #19 Posted September 20, 2019 27 minutes ago, Lonnie said: do you know what in-line filter and gas line I need? 1/4" rubber fuel line and a regular see-through fuel filter will do the trick. @WHX24 types faster than me! Share this post Link to post Share on other sites
WHX?? 56,847 #20 Posted September 20, 2019 Thank you Richard I ain't smart enough to do links on a stupid tablet either. Sediment bowls are old skool and cool but many here don't like them as they tend to leak and often don't catch all the dirt. The filters above are readily available at most hardware stores or on line. Let us know you need more help. 1 Share this post Link to post Share on other sites
