ptracy70 2 #1 Posted September 17, 2019 where is the BEST place to get parts and rebuild kits for k181. top quality. thanks. also is buy used one parts better than new Share this post Link to post Share on other sites
953 nut 62,151 #2 Posted September 17, 2019 Once the engine is apart and has been measured by a machine shop you can begin searching for the needed parts. I wouldn't buy anything prior to having the measurements done. You can find NOS (new old stock) Kohler parts on from time to time, but the aftermarket kits are good quality and cost far less. here are a few of places to shop. https://isavetractors.com/ https://a-ztractor.com/ http://gardentractorpullingtips.com/catalog.htm#rebuildparts 3 1 Share this post Link to post Share on other sites
Achto 29,806 #3 Posted September 17, 2019 8 hours ago, phil t said: where is the BEST place to get parts and rebuild kits for k181 Like stated above have the cylinder bore & crank measured before ordering any parts. You will need to know if you'll need an over sized piston or under sized rod. Here is one more source for parts. http://www.psep.biz/store/kohler_rebuild_kits.htm 3 Share this post Link to post Share on other sites
pacer 3,177 #4 Posted September 17, 2019 Agree with all the above --- these after market 'overhaul kits' seem to be quite good and are amazingly inexpensive. I have used some 6-8 of the 'kits' and dont know how many gasket sets and had very good luck with them. Received wrong set of rings one time, but seller quickly made good on it. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,340 #5 Posted September 17, 2019 I would also try lsavetractors.com norman is a great guy! 1 1 Share this post Link to post Share on other sites
WHX?? 52,898 #6 Posted September 17, 2019 Sounds like the guys have you covered so I'll just 1 Share this post Link to post Share on other sites
bottjernat1 2,194 #7 Posted September 17, 2019 i save tractors and stens Share this post Link to post Share on other sites
