Guest 88vic #1 Posted September 14, 2019 Any suggestions or previous experience of freeing up clutch pedals on the 3/4 inch rods ? Other than heat and penetrating oil. Really stuck on there. Thinking of cutting them off but dont really want to. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,998 #2 Posted September 14, 2019 Got a stick welder? Clamp a piece of scrap metal to the round bar. Put the ground clamp on the pedal. Crank it up and run a few beads on the scrap metal. The current running through the rust will heat it up and should blow the rust out. Garry 3 1 Share this post Link to post Share on other sites
Guest 88vic #3 Posted September 14, 2019 Thanks Garry, I will try that ! Ill let you know the outcome. Share this post Link to post Share on other sites
The Tuul Crib 7,340 #4 Posted September 15, 2019 2 hours ago, WHEELHORSEFAN*16 said: Thanks Garry, I will try that ! Ill let you know the outcome. Lots of heat! I use a small torch used for sweating copper pipes. Use map gas Share this post Link to post Share on other sites
adsm08 4,195 #5 Posted September 15, 2019 I've had good luck gooping open ends with anti-seize and heating the work piece until the anti-seize runs in. Usually a butane torch is enough heat for that to work. Share this post Link to post Share on other sites
troutbum70 858 #6 Posted September 15, 2019 Be interesting to hear how Gary's idea works. Share this post Link to post Share on other sites
SylvanLakeWH 30,592 #7 Posted September 19, 2019 Just freed up one on my C85 95 105 hybrid build... Used pb blaster, heat, time...tap back and forth...repeat... There is also a small hole on my pedal where it attaches to (around) the 3/4 rod...goes through to the rod...I liberally applied pb blaster in that as well and it soaked in and through... Share this post Link to post Share on other sites
