p38js 441 #1 Posted September 9, 2019 Ok guys, I finally tracked down a Kohler K91T with a retractable pull start for the suburban my daughter and I bought at the big show, I need some help and ideas on what to do about the exhaust. The block is not threaded and I can not find an adapter that is 1 1/4” between mounting stud centers. I’m thinking I will need to fabricate my own adapter unless you guys have a good solution to my problem. 1 Share this post Link to post Share on other sites
Racinbob 12,669 #2 Posted September 9, 2019 I tapped mine to 1/2" NPT, used a short nipple and went to 3/4" pipe. It threads easily and the smaller nipple won't harm a thing. Make sure you take precautions to keep shaving out of the engine. 3 Share this post Link to post Share on other sites
Lane Ranger 11,741 #3 Posted September 9, 2019 I had one like that threaded at a machine shop and it cost me $25. I did not have a tap for it and my vise and tool bencgh was not adequate to hold in place anyway. 1 Share this post Link to post Share on other sites
p38js 441 #4 Posted September 9, 2019 Thank you guys sounds like a good plan, I will look into a tap and check the machine shop. 1 Share this post Link to post Share on other sites
Pullstart 68,776 #5 Posted September 9, 2019 Yeah, a pipe tap is a handy tool to have around! Let us know how it turns out! 1 Share this post Link to post Share on other sites
953 nut 63,974 #6 Posted September 9, 2019 You can probably find a good used 1/2" NPT tap on , that is where I bought mine. Share this post Link to post Share on other sites
p38js 441 #7 Posted September 9, 2019 19 minutes ago, 953 nut said: You can probably find a good used 1/2" NPT tap on , that is where I bought mine. I have been looking at them, probably will order one soon. Always skeptical to the quality on EBay Share this post Link to post Share on other sites
cafoose 3,575 #8 Posted September 9, 2019 I just got a set of pipe taps off eBay looks like this made by Alfa Tools 1/4 to 1-1/2 if you need help with a tap: 1 Share this post Link to post Share on other sites
AMC RULES 37,254 #9 Posted September 9, 2019 Pretty easy to do. But, if you only do one in your lifetime... the local machine shop is the way to go. 1 Share this post Link to post Share on other sites
p38js 441 #10 Posted September 10, 2019 4 minutes ago, AMC RULES said: Pretty easy to do. But, if you only do one in your lifetime... the local machine shop is the way to go. But this a great excuse to get new tools past the boss lady 2 1 Share this post Link to post Share on other sites
AMC RULES 37,254 #11 Posted September 10, 2019 Does she ask you when she needs new underwear? 1 4 1 Share this post Link to post Share on other sites
953 nut 63,974 #12 Posted September 10, 2019 15 minutes ago, p38js said: Always skeptical to the quality on EBay I always buy american made used taps and other tools. 2 Share this post Link to post Share on other sites
cafoose 3,575 #13 Posted September 10, 2019 Just now, 953 nut said: I always buy american made used taps and other tools. I googled Alfa Tools and they seem to be high quality and American made. The set I got was used. They sell for $119.08 on amazon. https://www.alfatools.com/AlfaTools.htm https://www.amazon.com/Alfa-Tools-TDS66006NPT-Carbon-Steel/dp/B01LZVJV6N/ref=asc_df_B01LZVJV6N/?tag=hyprod-20&linkCode=df0&hvadid=310828259700&hvpos=1o1&hvnetw=g&hvrand=16124062837490360983&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9006755&hvtargid=pla-571300678458&psc=1&tag=&ref=&adgrpid=65583250281&hvpone=&hvptwo=&hvadid=310828259700&hvpos=1o1&hvnetw=g&hvrand=16124062837490360983&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9006755&hvtargid=pla-571300678458 1 Share this post Link to post Share on other sites
oldredrider 2,553 #14 Posted September 10, 2019 NAPA carries that size tap in stock. Not expensive and lasts a lifetime. 2 Share this post Link to post Share on other sites
Racinbob 12,669 #15 Posted September 10, 2019 2 hours ago, Lane Ranger said: I had one like that threaded at a machine shop and it cost me $25. I did not have a tap for it and my vise and tool bencgh was not adequate to hold in place anyway. Shoot Lane, you're close enough you should have come over. You don't need a vice or massive bench. It taps very easily. I started with a taper tap and followed up with a bottom tap. 1 hour ago, p38js said: I have been looking at them, probably will order one soon. Always skeptical to the quality on EBay That's where I got both the taper and bottom. They were cheap but seem to be good quality. I'm not gonna be doing 100's of them anyways. 2 Share this post Link to post Share on other sites
AMC RULES 37,254 #16 Posted September 10, 2019 No need to bottom the tap out... couple decent threads is all it takes. 1 Share this post Link to post Share on other sites
Racinbob 12,669 #17 Posted September 10, 2019 After I did the first one the taper tap went deeper than I thought it would. I picked up the bottom tap because I didn't think it would. I used it anyways to better hide the 1/2" close nipple. 1 Share this post Link to post Share on other sites
clueless 3,347 #18 Posted September 10, 2019 12 hours ago, AMC RULES said: Pretty easy to do. But, if you only do one in your lifetime... the local machine shop is the way to go. 1 Share this post Link to post Share on other sites
