The Tuul Crib 7,354 #1 Posted September 6, 2019 Flipping through Facebook I came across this tractor in Owensboro Kentucky about two hours up the road. Not sure what model this might be or what transmission might be in it. It is an automatic and maybe someone might know anything about it . 1 Share this post Link to post Share on other sites
953 nut 66,572 #2 Posted September 7, 2019 Probably a C-175, 1980 or so. Some C-175s had Sundstrand transmissions and some had Eaton. If there is a photo from the rear and you see the filter at the rear it is an Eaton. Share this post Link to post Share on other sites
The Tuul Crib 7,354 #3 Posted September 7, 2019 Hes strong at a hundred . Said it ran great till a screw fell done the carb. 2 Share this post Link to post Share on other sites
Pullstart 70,103 #4 Posted September 7, 2019 It’s worth a shot.... maybe! 1 Share this post Link to post Share on other sites
953 nut 66,572 #6 Posted September 7, 2019 9 hours ago, The Tool Crib said: Said it ran great till a screw fell done the carb. Presuming the screw never made it to a cylinder it would be a great deal! The route from the air cleaner to the cylinder is a tortuous path with lots of twists and turns along the way so it may be in the carburetor or manifold. 1 Share this post Link to post Share on other sites
pfrederi 20,665 #7 Posted September 7, 2019 Only some of the early 1980 C-175 had Sunstrands. All 81-84 C175 had Eatons. The full screen over flywheel looks more like a later KT 17 maybe even a Series 2 which would make it an 83/84 and even more desirable. 1 Share this post Link to post Share on other sites
