Bub43780 0 #1 Posted September 5, 2019 I have a 416h and it just started not going to neutral when brake is set. It looks like it’s in right position on the cam under the seat but has to be shifted off that point to get neutral. Share this post Link to post Share on other sites
CountryRock 199 #2 Posted September 6, 2019 Here is the service manual for the Eaton transmission in your tractor. It will tell you how to adjust the neutral position on it. Share this post Link to post Share on other sites
rmaynard 16,690 #3 Posted September 6, 2019 What year is your 416-H? My 416-H had the motion control lever on the steering column and all the linkage was worn. Replacing all the worn parts and then adjusting it by the manual fixed the neutral issue. However, I did replace all that later with a foot pedal kit. 1 Share this post Link to post Share on other sites
DougC 2,643 #4 Posted September 6, 2019 I bought an 88 520H that when you pushed the brake pedal the motion lever would not move back to stop. After removing some side covers and top plate I discovered it was not hooked up properly linkage wise. You never know who has been the last monkey with pliers and a screw driver "working" on the tractor. Share this post Link to post Share on other sites
bub 1 #5 Posted September 6, 2019 Mine is a 1995 . I bought this tractor new . The problem wasn't gradual,it just all of a sudden started Share this post Link to post Share on other sites
bub 1 #6 Posted September 7, 2019 What about the foot pedal kit? Sounds awesome, the shift lever is the only complaint i have ever had about my Wheel Horse Share this post Link to post Share on other sites
jay bee 915 #7 Posted September 8, 2019 Try this link in the vendor section. Complete Pedal Kits for Hydrostatic Wheelhorse / Toro Tractors Share this post Link to post Share on other sites
jay bee 915 #8 Posted September 8, 2019 My bad!!! That didn't work as a link. Go to the vendors section here and click on Matt's Custom Hydro Pedal Kit. Share this post Link to post Share on other sites
