hp73vettes
c160 auto deck lift cylinder
hp73vettes
hello all i am new to this so, here goes.  i have a 77 c160 auto and have been trying to locate a deck lift cylinder. mine is the welded one so rebuilding it is a little difficult. would anybody know if other model tractors use the same cylinder or something fairly close in dimensions,and has the snap ring on it to open it up and rebuild it.
RandyLittrell
:WRS:      Welcome, you have found the right place!
This gentleman can rebuild it and he is a member here. He has lots of other good stuff too.
https://www.wheelhorsepartsandmore.com/hydraulics.html
Randy
The Tuul Crib
:text-welcomeconfetti:to:rs:
:wwp:!! Some times we like pictures
it easier for us to help you with what you need
hp73vettes
thank you. ill get a tape measure and take some pics of it and post them
hp73vettes
Hope these help.  It's 10 7/8 closed and 15 7/8 open measured center to center of pin holes
The Tuul Crib
If you dont have any luck l do have one pm me
Edited by The Tool Crib
hp73vettes
thank you very much....
hp73vettes
Figured I'd post a pic of it
  • Like 5
daveoman1966
I had the same issue with my 75 C-160.  The OEM cylinger is # 6618 (A  below).
Found one that is rebuildable from a 77 C-=160. and it is like 'B' in this pic...part # 105254 but it is marked discontinued.
Cyl 'C" is this pic is a bit shorter and MAY not suit your need.  It is from a C=141 (I think)...
Cyl 'D' is definitely too short as it is frm a 520-H.
Edited by daveoman1966
hp73vettes
i really appreciate that info way above and beyond what i expected.  i do have a lathe and can weld. i just was worried if i made a mistake i would be up the creek without a paddle.  i will do a little surfing see what i can come up now that i have more info...  thanks again
daveoman1966
I also had a cyl 6618 leaking on the end seal.  (1)Take the threaded clevis off.  (2) Find a steel flat washer with ID to just fit over the ram with a OD near OD of cylinder housing....and an O-ring too to fit onto the ram.
(3) Drill 3 holes (equally) around flat washer and mark those hole location on the end of the cylinder.  (4)Drill the three marked holes about 1/2" deep...or enough to tap threads for 3 small screws.  (5)Put the O-ring onto the ram, slide the washer onto the O-ring, then tighten the 3 screws.... This pinches to O-ring and stops cylinder leaks.  It's been there for 7 or  8 years now and I use the tractor almost daily.
hp73vettes
That's a good idea.  The cylinder itself has pressure. It will raise and lower the Deck.  It seams to leak more when it is retracted. Seems to leak a little more with the weight of the plow I am installing  I'll give it a try.  It can't hurt.
hp73vettes
I have another question.  To set up a plow. Should I use the pivot point where the plow attaches to the front of the tractor or lift it from the middle of the plow with the mower lift arm.  I only tried to set the plow up using the pivot point in front . It hooks up in the rear and where the mule drive was. But not sure which method to use for lifting it
daveoman1966
Once hooked to the rear Tach-o-Matic hitch, the front MULE drive removed, the lift point of the dozser blade is like this...usually with a chain...but a lift bar can also be used as an alternative.  A long flat bar can also be used which will allow DOWN pressure...
hp73vettes
thanks again. the plow set up that i purchased had a link and pivot point that went where the mule drive was mounted. it must of been for a manual lift. i was trying to set up a rod that went to the deck lift arm. it worked but didnt have much lift height. i see by your pic it can be lifted from the middle. ill have to weld up a bracket at mid point of plow frame like the one in the pic you posted. and i will try the washer and oring idea while i search for a lift cylinder thats rebuildable.... thanks again for your help.
ZXT
Now that is one beautiful tractor! Did you restore it yourself or did you buy it that way?
If the mechanical parts of the tractor are in as good of shape as the rest of the tractor looks, then you have a tractor that will last you a lifetime.
Needless to say, I'm a bit jealous!
What's the lever that's sticking up in front of the seat? My c160 doesn't have it.
hp73vettes
thank you for the kind words. i did the restore myself . the lever in front of the seat is to release the seat pan to gain access to hydro fill tube / box under seat
daveoman1966
Not to burst any bubble or to be picayune, but the Motion Control Lever shown on this tractor is a trademark of the 1973 'No-Name' year.  The Motion Lever is between your knees which is a little awkward.  I know that because I owned a 1973 12hp Automatic of exactly same setup...it was model 1-0465.
Given that distinction, your tractor decals would be simply "16hp Automatic" (instead of '"C-160") and the model number would be 1-0440.  In 1974 the official C-160 was born and the Motion Lever was changed to a tall vertical arm on the Right side...approx the height of the steering wheel...making it much easier to control fwd/rev directions and speed.
Just thought I'd throw that out there.
hp73vettes
thats good info to know.  i only replaced what was previously on the machine.  no bubbles popped here...
daveoman1966
Regardless....thats a VERY nice machine.  Tractors like that cause addictions, ya know..... lol
hp73vettes
yes i do. it was my dad that started it with a 67ish lawn ranger which i still have today but it had a hard life. maybe some day ill try and bring her back..
hp73vettes
thanks again to daveoman1966.....
