carlosking450 161 #1 Posted September 5, 2019 Hello in my 702, is there a bit of play between the steering column and the hole in the tank, do you know if there is any bushing to correct this slack? Share this post Link to post Share on other sites
953 nut 64,124 #2 Posted September 6, 2019 I do not own a 702 but know that the steering shaft play is a common problem on other older models and can be corrected by dding a 3/4" bearing (flanged pillow block) where the steering shaft passes through the body. Share this post Link to post Share on other sites
Pullstart 68,883 #3 Posted September 6, 2019 @carlosking450 I believe there is a brass bushing in the tank. Here is a link to my “Frank” build, where I was working on sealing the tank after some modifications to the bottom. That bushing should be able to press out, then press a new one in (and possibly ream it to fit). 1 Share this post Link to post Share on other sites
carlosking450 161 #4 Posted September 6, 2019 Hello friends, I remember to see something about a cap for sale for that game between the column and the tank, I will have to make one, it is simply a bronze cap, thanks for your answers !!! 1 Share this post Link to post Share on other sites
