DonaldMazzDerby 1 #1 Posted September 4, 2019 Hello all, I recently aquired a b-115 and a-100. I would like to convert the rear wheels to four bolt. does anyone know of an adapter or know the spindle and key size so i can source without pulling the whole tractor apart? Share this post Link to post Share on other sites
Achto 31,004 #2 Posted September 4, 2019 I don't know what the specs are on the axles, but someone should be along soon with an answer. Share this post Link to post Share on other sites
Stormin 9,987 #3 Posted September 4, 2019 Can't help you I'm sorry to say but Curious as to why you want to change to 4 stud though. Share this post Link to post Share on other sites
ebinmaine 77,340 #4 Posted September 4, 2019 Just now, Achto said: I don't know what the specs are on the axles, but someone should be along soon with an answer. Share this post Link to post Share on other sites
DonaldMazzDerby 1 #5 Posted September 4, 2019 3 minutes ago, Stormin said: Can't help you I'm sorry to say but Curious as to why you want to change to 4 stud though. Thank you all, As far as why i want to change...I dont know, just always liked 4 stud and how i can have multiple cheap wheels set up with different tires depending on what i need to do. 1 Share this post Link to post Share on other sites
ebinmaine 77,340 #6 Posted September 4, 2019 1 minute ago, DonaldMazzDerby said: Thank you all, As far as why i want to change...I dont know, just always liked 4 stud and how i can have multiple cheap wheels set up with different tires depending on what i need to do. That's reasonable. I have the standard 5 stud in different ways for the same reason. Share this post Link to post Share on other sites
Tractorhead 9,216 #7 Posted September 4, 2019 to sorry, can‘t help, but i‘m sure several Fellas here can Share this post Link to post Share on other sites
wallfish 19,309 #8 Posted September 4, 2019 Pretty sure those axles are 3/4 https://www.ebay.com/itm/4-x-4-Wheel-Hub-3-4-Rear-Bore-Go-Kart-Parts-Cart-Lawn-Mower-Drift-Trike-New/143330843266?hash=item215f2f1a82:g:LyQAAOSwWkRdLi48:sc:USPSPriority!01524!US!-1 1 Share this post Link to post Share on other sites
857 horse 2,588 #9 Posted September 4, 2019 SO,,,,YEAH WANNA CHANGE......HERE GOES THE 5 LUG IS 5 ON 4 1/2 -------------TAKE A MEASURING DEVISE.....MEASURE ACROSS ( ON THE 4 BOLT RIMS ) THAT WILL MAKE IT 4 ON,,WHAT EVER THAT MEASUREMENT IS,,,,,,WITH THAT,,,,,GO TO EBAY,,,,SEARCH WHEEL ADAPTER,,,,AND INSEERT BOTH SIZES.....THE LAST THING YOU NEED IS HOW THICK.....1 INCH? 2 INCH?? GOOD LUCK 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,000 #10 Posted September 4, 2019 Early B-115's use 104636 3/4" wheel retaining ring and later use a 5700 1" wheel retaining ring with Peerless 5-speed trans. Garry Share this post Link to post Share on other sites
