Lee1977 7,432 #501 Posted April 8, 2020 3 hours ago, ebinmaine said: The 12" wheels I'm using are 4" or five" wide. Your measurement makes pretty good sense. I'm aiming for an outside width of about 38 - 40 or so. Are you going to have enough clearance for those taller wheel and tires, you have a big wide engine upfront. 1 Share this post Link to post Share on other sites
Stormin 9,986 #502 Posted April 8, 2020 Don't know the width on the Black Horses front wheels. Most likely the same as Lee's. Looks like we used the same trailer wheels etc. 1 Share this post Link to post Share on other sites
Cvans 1,009 #503 Posted April 9, 2020 10 hours ago, Tractorhead said: Huh, chickens and horses, that must be a Farm... 👍 If'n you ain't got a manure spreader it no dang farm. The wife don't count none either. 3 Share this post Link to post Share on other sites
Cvans 1,009 #504 Posted April 9, 2020 It's been awhile since I checked but it seems like you need to meet two of the three following requirements. Be over 20 acres and you need to generate above so much of your income from the land. or so many acres has to be in farm production. They are trying to keep tillable land of being broken up into small plots. Also only four residents to a section. We own farmland but because our home is not on that land and is only 8 acres it is not considered ag land and therefore taxed higher. Go figure. 1 Share this post Link to post Share on other sites
Cvans 1,009 #505 Posted April 10, 2020 Go for it, Maybe you will start a new trend. 1 Share this post Link to post Share on other sites
