Pullstart 70,322 #1226 Posted September 27, 2021 to RedSquare Colossus! I’m so excited for a new build! EB. KBS three part fuel tank sealer. It rocks. Lots. Of. Words. 2 Share this post Link to post Share on other sites
SylvanLakeWH 31,656 #1227 Posted September 27, 2021 I wouldn’t worry about a gas tank… by the time this baby gets running we’ll all be using a proton physical particle emulsifying separator for propulsion and the UN will have banned internal combustion engines… 7 Share this post Link to post Share on other sites
ebinmaine 79,420 #1228 Posted September 27, 2021 27 minutes ago, pullstart said: Lots. Of. Words I see what you did there... Hey thanks for the lead on that sealer. I'll check it out. 3 Share this post Link to post Share on other sites
wallfish 20,128 #1229 Posted September 28, 2021 On 9/27/2021 at 6:35 AM, ebinmaine said: Certainly open to suggestions Well, I have a spare Roof 60 tank if you think it will fit into your plans. It's big but you're going wide so.... Take a look at the pic and I can get you measurements if you're interested. (And it's red) 1 Share this post Link to post Share on other sites
ebinmaine 79,420 #1230 Posted September 28, 2021 20 minutes ago, wallfish said: going wide How wide is that Roof tank John? Looks like maybe 25" or so? That's bigger than I'd originally envisioned but now that you mention width, my front axle is about 40, 41 inches across soooo yours might be a good fit. Share this post Link to post Share on other sites
wallfish 20,128 #1231 Posted September 28, 2021 5 minutes ago, ebinmaine said: How wide is that Roof tank John? 28 X 14 X 6 deep Almost 10 gallons capacity. The angles take away some of the calculated volume with those measurements. Useful amount is probably 8 gallons so that'll keep ya going a little while without running dry Share this post Link to post Share on other sites
ebinmaine 79,420 #1232 Posted September 28, 2021 16 minutes ago, wallfish said: 28 X Yeeesh. I like the look but that's pretty wide. I'll pass for now. I REALLY appreciate the offer though! Share this post Link to post Share on other sites
wallfish 20,128 #1233 Posted September 28, 2021 No Problem. Told ya it was big! LoL Cutting the end off and shorting it makes it an adjustable tank. You got a welder now 2 Share this post Link to post Share on other sites
ebinmaine 79,420 #1234 Posted September 28, 2021 4 minutes ago, wallfish said: No Problem. Told ya it was big! LoL Cutting the end off and shorting it makes it an adjustable tank. You got a welder now Not sure letting me anywhere near a GAS tank with a welder is the best idea..... Share this post Link to post Share on other sites
Oldskool 6,678 #1235 Posted September 28, 2021 If you really want to use your riveted tank this sealer works quite well. It's held up for a year so far without issues. 2 2 Share this post Link to post Share on other sites
Maxwell-8 4,371 #1236 Posted October 26, 2021 On 4/23/2021 at 2:12 AM, ebinmaine said: Man those heads are huge in comparision to my KT17, sparkplug also has a special placement. 1 Share this post Link to post Share on other sites
ebinmaine 79,420 #1237 Posted October 26, 2021 1 minute ago, Maxwell-8 said: huge in comparision to my KT17, Everything about this engine is beast-sized. Several inches larger than a 17 or 18 block in every way. Can't even mount a clutch pedal on the tractor. I'll be using a hand clutch for this one. 1 1 Share this post Link to post Share on other sites
Oldskool 6,678 #1238 Posted October 26, 2021 I saw the name Colossus in my notifications. I said WHAT THE.... I had to come check it out. lol 2 1 1 Share this post Link to post Share on other sites
ebinmaine 79,420 #1239 Posted October 26, 2021 40 minutes ago, Oldskool said: I saw the name Colossus in my notifications. I said WHAT THE.... I had to come check it out. lol You'll see that more often....soon. The BBT has decided it should be completed and put to work. Also... Out of the basement workshop taking up space. 😂😂😂 3 Share this post Link to post Share on other sites
SylvanLakeWH 31,656 #1240 Posted October 26, 2021 1 Share this post Link to post Share on other sites
ebinmaine 79,420 #1241 Posted October 26, 2021 4 minutes ago, SylvanLakeWH said: My apologies for waking you. 1 Share this post Link to post Share on other sites
Pullstart 70,322 #1242 Posted October 26, 2021 17 minutes ago, ebinmaine said: The BBT has decided it should be completed What took her so long? The way she gets things done, it’ll be finished last week by tomorrow! 2 Share this post Link to post Share on other sites
8ntruck 9,013 #1243 Posted October 26, 2021 While reading up on KT's, I stumbled across a stement that the big KT has spray type lube like the series 1 KT's. If true, this might be something to keep in mind while operating on your nice, smooth, level property. 1 Share this post Link to post Share on other sites
ebinmaine 79,420 #1244 Posted October 26, 2021 15 minutes ago, 8ntruck said: While reading up on KT's, I stumbled across a stement that the big KT has spray type lube like the series 1 KT's. If true, this might be something to keep in mind while operating on your nice, smooth, level property. This beast has an oil filter so it's a pressurized system. It's likely a second generation engine. Date of manufacture is unknown and unable to be found due to decal damage. Share this post Link to post Share on other sites
ebinmaine 79,420 #1245 Posted October 26, 2021 26 minutes ago, 8ntruck said: nice, smooth, level property Share this post Link to post Share on other sites
8ntruck 9,013 #1246 Posted October 26, 2021 1 hour ago, ebinmaine said: This beast has an oil filter so it's a pressurized system. It's likely a second generation engine. Date of manufacture is unknown and unable to be found due to decal damage. That's good news, then. 1 Share this post Link to post Share on other sites
oliver2-44 11,593 #1247 Posted October 26, 2021 2 hours ago, ebinmaine said: BBT has decided it should be completed and EB put to work 😂😂😂 Things will be happening now! 1 1 Share this post Link to post Share on other sites
Lee1977 7,667 #1248 Posted November 1, 2021 EB got it made and don't know it. Has Trina to hold those heavy transmissions in place while he puts the bolts in. I'm almost twice as old and had to do it all myself. I saw those pictures of Trina moving the big 16 HP Kohler around. You better get busy and get that thing out of her shop before she pushes it out in the snow to rust. 1 Share this post Link to post Share on other sites
ebinmaine 79,420 #1249 Posted November 1, 2021 3 hours ago, Lee1977 said: EB got it made and don't know it Oh YES he does!!!! 3 hours ago, Lee1977 said: get that thing out of her shop before she pushes it out in the snow to rust A. She respects equipment way too much to ever think about that. B. As of this past weekend I now have FOUR C160s. Certainly worth delaying the rest of world a bit more.... 3 Share this post Link to post Share on other sites
Stormin 9,988 #1250 Posted November 1, 2021 On 10/26/2021 at 9:21 PM, oliver2-44 said: Things will be happening now! Maybe done by Christmas. Not saying which Christmas though. 1 3 Share this post Link to post Share on other sites
