Tony D64 3 #1 Posted August 26, 2019 No power to blue wire to solenoid . No Power at nine pin connection blue wire When I discontinue and wiggle and tug blue wire at starter end 2 of the three relays make noise. Middle one (start relay ) Ana one on right sitting on mower. Can jump starter with with battery charger and everything runs well !!!! I tried to swap out one rely , can it be two bad ones ?? Ignition switch tested good. Frame ground good. Fuses ok. All safety switches seem ok ?? I think. Heip Share this post Link to post Share on other sites
Tony D64 3 #2 Posted August 26, 2019 Also , all gauges and dummy lights work as they should once running. Tested both sides of the nine pin connector at blue wire. Neither side had power ..???? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,846 #3 Posted August 26, 2019 These should help. Click on the picture If you need the procedure to test a component enter the part number in the manuals search box and search. Garry 1 Share this post Link to post Share on other sites
Tony D64 3 #4 Posted August 26, 2019 Wow great G-west !! Will check these out thanks very much !!! wii let ya know how I make out. 2 Share this post Link to post Share on other sites
953 nut 63,026 #5 Posted August 26, 2019 Many of your electrical components are located under the battery and there is a good chance they have some corrosion that needs to be cleaned up. Share this post Link to post Share on other sites
