XLT 13 #1 Posted August 23, 2019 1961 model 701 I took the transmission out to replace the shifter and unbolted the whole thing but I cannot separate the haves. Any hints or tricks? Share this post Link to post Share on other sites
ebinmaine 76,652 #2 Posted August 23, 2019 The ones I've done I very gently take a wood chisel that is maybe 1.5 in wide and tap it against the gasket all the way around the case. on the second revolution you can start to see things separating a bit. Be gentle. Be gentle. Be gentle. You'll get the feel for it. 2 1 Share this post Link to post Share on other sites
McGrew 461 #4 Posted August 23, 2019 I started mine with a sharp, stiff putty knife. Danny 2 Share this post Link to post Share on other sites
XLT 13 #5 Posted August 23, 2019 Got it separated about 3/4". Doesn't seem to want to separate any further. Of course, it's dry as a bone in their looks like it hasn't seen or oil since the 70s. The remnant of a broken shift Rod is sticking down in there rusted stiff. And one of the shifter rails that seems to be stuck down nothing moving Any further ideas? Share this post Link to post Share on other sites
ebinmaine 76,652 #6 Posted August 23, 2019 4 hours ago, XLT said: further ideas? This is where you will want penetrating oil and lots of patience. Look and see wherever it's still attached. Oil that. Tap it back together a little. Oil again. Separate a little. Repeat as needed..... Share this post Link to post Share on other sites
Racinbob 12,510 #7 Posted August 23, 2019 I've used the wood chisel as mentioned. Works well but you've got yours past that point. It sounds to me like it's hanging up on one of the shafts. Push the case halves back together and clean all the shafts well. Use emery paper to get rid of the burrs, rust etc. 2 1 Share this post Link to post Share on other sites
953 nut 63,633 #8 Posted August 23, 2019 7 hours ago, XLT said: Any further ideas? After cleaning up the shafts and lubricating everything you may want to cut four hardwood wedges and tap one into each corner. Go around the transmission case from corner to corner tapping the wedges in to gently pry them apart. 2 Share this post Link to post Share on other sites
WHX?? 53,916 #9 Posted August 23, 2019 Sounds like the guys have got you covered ... Here's a transmission manual in case you don't have one. 492-4004.pdf 2 Share this post Link to post Share on other sites
XLT 13 #10 Posted August 23, 2019 (edited) Thanks for the help, guys. I tried the hardwood wedges and they did get it a little further separated. I'll keep at it. Part of the issue, and I'm not sure is that the shifter was broken off and what remains is frozen pretty badly... does this transmission need to be in neutral to separate the halves? Because it's not... and nothing in that region seems to be moving right now to get it into neutral. Edited August 23, 2019 by XLT Share this post Link to post Share on other sites
XLT 13 #11 Posted August 23, 2019 I ask because that's a step in the manual, but that's for complete disassembly, which may not be necessary for this. Share this post Link to post Share on other sites
953 nut 63,633 #12 Posted August 23, 2019 11 hours ago, XLT said: it's dry as a bone in their looks like it hasn't seen or oil since the 70s. You may want to lay it on one side and squirt a lot of penetrating oil on each shaft, then roll it over the next day and do the same thing. parts that have been dry that long could be rusted in place. 1 Share this post Link to post Share on other sites
953 nut 63,633 #13 Posted August 23, 2019 48 minutes ago, XLT said: Part of the issue, and I'm not sure is that the shifter was broken off and what remains is frozen pretty badly... does this transmission need to be in neutral to separate the halves? Because it's not... and nothing in that region seems to be moving right now to get it into neutral. The portion of the shift lever that is in the shift forks will hold tight to the fork it is in. If need be you may want to drill down through what is left of the lever to free it from the ball. Start small and work your way out to 3/8" That should let the internal part of the shift lever to fall out of the fork. Share this post Link to post Share on other sites
XLT 13 #14 Posted August 23, 2019 I may have it far enough apart to get a reciprocating saw on that piece... but that might be the 100lb. hammer approach... 1 Share this post Link to post Share on other sites
ebinmaine 76,652 #15 Posted August 23, 2019 as long as you're careful not to nick anything else I don't see an issue using a reciprocating saw to get that shaft piece out of there Share this post Link to post Share on other sites
XLT 13 #17 Posted August 23, 2019 Would that chunk of shifter, stuck in one gear or another, keep the case from fully separating? Share this post Link to post Share on other sites
WHNJ701 4,168 #18 Posted August 23, 2019 if it's that dry, bolt it back together and fill it with kerosene and let it sit for a week or 2 1 Share this post Link to post Share on other sites
WHX?? 53,916 #19 Posted August 23, 2019 5 minutes ago, XLT said: Would that chunk of shifter, stuck in one gear or another, keep the case from fully separating? It shouldn't ....my guess is one of the shift rails is binding or the 1533 bearings don't know if they want to stay in the case half or on the axle shaft. Jabelman has a good idea. I have used the acetone and ATF mixture like that with good results. Actually made parts easier to clean once apart as well. 1 Share this post Link to post Share on other sites
XLT 13 #20 Posted August 23, 2019 One rail is def. engaged is definitely stuck in its position. I'll take some pics later... unfortunately, have to work in between tractor sessions and bee removals. 1 Share this post Link to post Share on other sites
stevasaurus 23,536 #21 Posted August 23, 2019 There is nothing in the case that will keep you from separating it. Make sure you are taking off the larger case half and leaving the shallow side. Like Bob said, you probably have some varnish or burrs that are holding you up. Emory cloth or a file for burrs will do the trick. The key ways could have burrs also. Share this post Link to post Share on other sites
953 nut 63,633 #22 Posted August 23, 2019 53 minutes ago, XLT said: unfortunately, have to work in between tractor sessions I remember how a job could interfere with fun, no rush, we will be here! 1 Share this post Link to post Share on other sites
Pullstart 68,682 #23 Posted September 7, 2019 What if you rotate input shaft and axles while you tap on the case? It shouldn’t matter if it’s in gear or not when you pull it apart, the shafts just drop in to the bushings/bearings of the case once it’s all clean. Share this post Link to post Share on other sites
