George Mingos 0 #1 Posted August 20, 2019 Coil good no spark now what? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,393 #2 Posted August 20, 2019 Welcome to the forum. Tell us more about your problem. Can you find a model number and serial number on your tractor? These diagrams are for 1987-1989 Click on the picture Garry Share this post Link to post Share on other sites
953 nut 59,297 #3 Posted August 20, 2019 7 hours ago, George Mingos said: Coil good no spark now what? Is your PTO switch turned off? How have you confirmed that the coil is good? The wire from the coil to the ignition switch will ground the coil to turn off the engine at the key, have you unhooked that wire to see if the spark returns? Share this post Link to post Share on other sites
George Mingos 0 #4 Posted August 20, 2019 (edited) Pto off coil tested with meter kill wire unhooked Edited August 22, 2019 by George Mingos Share this post Link to post Share on other sites
The Tuul Crib 7,339 #5 Posted August 20, 2019 to !!! Share this post Link to post Share on other sites
