KC9KAS 4,744 #1 Posted August 19, 2019 I am in need of a fuel pump mounting gasket for a K 141 (6.25 hp). Does anyone know the part number for the gasket? Thanks in advance. Share this post Link to post Share on other sites
953 nut 62,142 #2 Posted August 20, 2019 Why not buy some gasket material and cut your own? Share this post Link to post Share on other sites
WHX?? 52,898 #3 Posted August 20, 2019 Here's what I have ROT3542 rotary aftermarket, 2504110S Kohler OEM These are for a 241 & up but should be the same?? 11 hours ago, 953 nut said: and cut your own? Do you WANT me to bleed to death! 1 Share this post Link to post Share on other sites
953 nut 62,142 #4 Posted August 20, 2019 36 minutes ago, WHX24 said: for a 241 & up but should be the same Yes, the smaller engines used a vacuum pump rather than cam driven, but the housing is the same bolt flange mount. 1 Share this post Link to post Share on other sites
