handyman 1 #1 Posted April 14, 2009 I have an '85 416-8 with no engine. It originally had the single cylinder Kohler. I have found an 18 horse Magnum twin that I can put in. What do I have to change on the wiring since the original engine was point ignition and the Magnum is an electronic setup. I recall seeing that the ignition switch is different but do I have to change wiring? What years did they put the twin Magnum in the 416 and 418. I guess I could try to compare the wiring schematics. Thanks. Share this post Link to post Share on other sites
CasualObserver 3,415 #2 Posted April 14, 2009 Wheel Horse tractors by year and other information This can also be found in the Links thread at the top of the tractor forum under the heading History and Information. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,607 #3 Posted April 14, 2009 I know my 85 416 has a K series which I think were the factory motor for 85 and 86. 87 is the first year of the magnum. I do not know what needs to be done to get the 18hp in there. Good luck- Share this post Link to post Share on other sites
Buzz 502 #4 Posted April 14, 2009 In 1987 the 416-6 model # 31-16K803 had a M16S-711523 engine and the 418-8 model # 31-18K801 had a M18QS-24510 engine. If you go here: https://lookup3.toro.com/request/request.cfm and enter 31-16K803 for model number and "none" for the serial number you can download the 523 pg. Electricial Demystification guide for the wiring diagrams. Have fun. Share this post Link to post Share on other sites
handyman 1 #5 Posted April 14, 2009 Thanks guys! I am am thinking "what have I gotten myself into" when you closing comments are good luck and have fun. Share this post Link to post Share on other sites
