rem722 26 #1 Posted August 16, 2019 (edited) Hi guys, two questions here: 1. can you change the deck belts by removing hold down bolts on bearing bracket(next to pully) and sneak belts off and on??? 2. my deck seems to leave two strips of cut grass (seems like it discharges cut grass right under each rear tire) is the blades going backwards? I thought one blade going cw and other ccw meant the grass discharged in middle of rear deck??? Edited August 16, 2019 by rem722 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,907 #2 Posted August 16, 2019 Remove the bolts from the right bearing block and loosen the bolts on the left one. That should let you lift the right side enough to get the belts in. Have lots of rags to keep grease off the belts. Make sure you time the blades at about 90 degrees to each other before you lower the shaft assembly. Garry 2 Share this post Link to post Share on other sites
AHS 1,567 #3 Posted August 17, 2019 with the deck off, on the blade you can read the numbers on the blade. The sharp end of the blade is closest to the ground. If that helps. Share this post Link to post Share on other sites
