Franky Figs 0 #1 Posted August 15, 2019 I am a newbie who has a 1979 C-81 and I am looking for the hand cable that controls the angle of the plow ! The iron handle is there but the cable that has the lever you squeeze is broken ! Thanks Frank Share this post Link to post Share on other sites
pfrederi 20,619 #2 Posted August 15, 2019 (edited) If you mean item 19 it was a rod not a cable. However you could use some cable and clamps to replace it Edited August 15, 2019 by pfrederi Share this post Link to post Share on other sites
ebinmaine 79,036 #3 Posted August 15, 2019 (edited) 10 minutes ago, pfrederi said: If you mean item 19 it was a rod not a cable. However you could use some cable and clamps to replace it I'd actually recommend doing what Paul said. Replace it with a cable. gives you a little bit of flexibility when you're trying to take the plow off and on the tractor. By the way. Welcome to Red Square! Edited August 15, 2019 by ebinmaine 1 Share this post Link to post Share on other sites
stevasaurus 23,689 #4 Posted August 15, 2019 I think it is actually like #109 wire, you can buy it at ACE, etc. 3 Share this post Link to post Share on other sites
Franky Figs 0 #5 Posted August 16, 2019 Thank you all for the info and the picture of the plow with the parts numbered ! I believe I am pretty certain that I need parts number 26,27 and 28 Share this post Link to post Share on other sites
Burnerman 759 #6 Posted August 16, 2019 If you have a welder it’s a very easy part to make. I can get you a close up pic if you’d like. Share this post Link to post Share on other sites
