Similar Content
By Duramax7man7
Very Solid tractor!
Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
$1175 OBO -POOS
(248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
By oliver2-44
I refurbished my 1985 Side Discharge Deck model j05-42MS04. And my son started mowing with it this summer on the 312-8. I've read many threads about these WH decks mowing low but were Texas newbies when it comes to mowing with them
So mowing low is a known issue but has anyone come up with a solution?
Since these decks are free floating has anyone tried installing larger rear deck wheels?? I'm thinking larger front roller would not help since if. I understand correctly these should not always be touching.
Im looking for ideas ?
I need a picture of the finished deck but you can see from these pics I completely disassembled the deck, replaced all bearing and sliders etc. Took it to bare metal. Did some straightening And repainted it.
By Yankee64
Hello,
I have a C-160 with 16HP Kohler that had a 42" deck on it. That deck needs some work so I switched it to my 5-0721 36" deck that I put a new deck belt and new blades on, but can't get it hooked up. I can't find the transfer belt size for this combo, I think that's what it's called, the belt to the PTO.
I don't know what I hit, but new kids across the ally have been throwing rocks in my yard at a ground hog (all over, they have rock pile from the garden) and whatever it was, it jammed on the spindle of the 42" deck and ripped the deck where the spindle mounts. I'm going to fix it up nice while it's not in use. Wouldn't you know, I started in the back yard and the front is starting to look bad. I've been fiddling for a few days and bought a couple of belts but haven't gotten it right. If anyone knows the belt size for a C-160 with a 5-0721 36" deck, I'd sure appreciate your assistance.
By Terry T
I have a 212-6 with a 36" mower deck
The owner's manual and parts list does not show a 36" one, only 30" one.
The v-belt no linger drives the deck.
Belt measures 115"+, but when I try a new 115"er, it is too short, and a 116" is too long.
What's up with that????
