rjg854 13,341 #1 Posted August 10, 2019 The little lady got me a set of tires as a present and you can see they are a bit out of shape . I remember a thread about this and tried the search. But dealing with tires the results are endless. What can I do to get them usable for mounting. Thanks Share this post Link to post Share on other sites
Racinbob 13,135 #2 Posted August 10, 2019 I've never tried it but I believe if you leave them out in the sun a while they will recover some. Then mount them and it may be a bit of a fight to get the bead to catch but once they do things will be fine. Share this post Link to post Share on other sites
953 nut 69,133 #3 Posted August 10, 2019 I have put tubes in tires and inflated them, then put them in the sun. 8 2 Share this post Link to post Share on other sites
dells68 7,499 #4 Posted August 10, 2019 I’ve done it with great results! Just take out the valve stem to deflate and you’re good to go! 1 Share this post Link to post Share on other sites
rjg854 13,341 #5 Posted August 10, 2019 Thanks for that idea Richard, sounds like that might be my best option I knew I could count on you guys for some great options 1 Share this post Link to post Share on other sites
squonk 48,063 #6 Posted August 10, 2019 Take em to Nolts to get them mounted Share this post Link to post Share on other sites
rjg854 13,341 #7 Posted August 10, 2019 I might if it doesn't work out, but my plan was to do myself. Share this post Link to post Share on other sites
SylvanLakeWH 32,457 #8 Posted August 10, 2019 37 minutes ago, 953 nut said: I have put tubes in tires and inflated them, then put them in the sun. 33 minutes ago, dells68 said: I’ve done it with great results! Just take out the valve stem to deflate and you’re good to go! Great idea...just curious - if you already have a tube and go to the trouble of inflating etc. why not just go with tubes installed and call it good? Thats what I did and it has worked great... 3 Share this post Link to post Share on other sites
ebinmaine 80,600 #9 Posted August 10, 2019 I'd leave them with tubes in. Is there a reason why you don't want tubes? 1 Share this post Link to post Share on other sites
rjg854 13,341 #10 Posted August 10, 2019 I think what Richard is saying is put the tubes in the tires before putting the tires on the rims. And leave them out in the sun. 5 Share this post Link to post Share on other sites
Pollack Pete 2,273 #11 Posted August 10, 2019 I've cut some scraps of 2 x 4 lumber a little longer than the width of your rims.Stick them between the beads of the tires to spread them apart.Leave them overnight.Mount on the rims in the morning.I've done this on car and truck tires too when I couldn't catch the beads when trying to air up new tires.Works for me. 2 Share this post Link to post Share on other sites
lynnmor 9,037 #12 Posted August 10, 2019 2 hours ago, Pollack Pete said: I've cut some scraps of 2 x 4 lumber a little longer than the width of your rims.Stick them between the beads of the tires to spread them apart.Leave them overnight.Mount on the rims in the morning.I've done this on car and truck tires too when I couldn't catch the beads when trying to air up new tires.Works for me. I've done the same thing but it took much longer than overnight. Some tractor tires are extremely stiff, and very distorted, so they take a long time to relax into the proper shape. Share this post Link to post Share on other sites
rjg854 13,341 #13 Posted August 10, 2019 I'm giving Richard's suggest a try. With just a tube inside the tire, that wasn't enough to get it to the shape it needed to be. So I added some plastic pails to the center of the tubes and helped quite a bit, now, time will tell. 2 1 Share this post Link to post Share on other sites
ebinmaine 80,600 #14 Posted August 10, 2019 1 minute ago, rjg854 said: I'm giving Richard's suggest a try. With just a tube inside the tire, that wasn't enough to get it to the shape it needed to be. So I added some plastic pails to the center of the tubes and helped quite a bit, now, time will tell. Looks like those should settle out fine. Will you be removing the tubes for installation? Share this post Link to post Share on other sites
clueless 3,438 #15 Posted August 10, 2019 (edited) 1 hour ago, rjg854 said: I'm giving Richard's suggest a try. With just a tube inside the tire, that wasn't enough to get it to the shape it needed to be. So I added some plastic pails to the center of the tubes and helped quite a bit, now, time will tell. What,s the old saying about necessity, you done well. Edited August 10, 2019 by clueless spelling 2 Share this post Link to post Share on other sites
rjg854 13,341 #16 Posted August 10, 2019 4 minutes ago, ebinmaine said: Looks like those should settle out fine. Will you be removing the tubes for installation? Planning on fluid filling the tires, and since I have them I just might 2 1 Share this post Link to post Share on other sites
ebinmaine 80,600 #17 Posted August 10, 2019 18 minutes ago, rjg854 said: Planning on fluid filling the tires, I'm a big fan of that. Share this post Link to post Share on other sites
953 nut 69,133 #18 Posted August 10, 2019 1 hour ago, rjg854 said: Planning on fluid filling the tires, and since I have them I just might The tubes will save your rims from rusting with the fluid fill. 1 Share this post Link to post Share on other sites
Pollack Pete 2,273 #20 Posted August 11, 2019 18 hours ago, rjg854 said: I'm giving Richard's suggest a try. With just a tube inside the tire, that wasn't enough to get it to the shape it needed to be. So I added some plastic pails to the center of the tubes and helped quite a bit, now, time will tell. Looks like a good idea,but if I tried that,I'd have to hide them in my shop...….The Squaw would probably fill them with dirt and plant flowers in them thinking they're some kind of planter.Haha. 1 3 Share this post Link to post Share on other sites
rjg854 13,341 #21 Posted August 11, 2019 21 hours ago, lynnmor said: I've done the same thing but it took much longer than overnight. Some tractor tires are extremely stiff, and very distorted, so they take a long time to relax into the proper shape. I'll leave them like that for probably a week. I've got the rims to clean up and paint yet anyways, so I'm in no great hurry to get them mounted. I did let the air off last night on one of the tires, and it obviously wasn't a long enough amount of time, or they didn't get warm enough in the sun. Either way, I'll let them stay for whatever amount of time it takes. 1 Share this post Link to post Share on other sites
JaysHorse 288 #22 Posted August 11, 2019 I’ve seen a video and have done it myself with using a bucket with a towel around the rim of the bucket to help inflate the tire. Although that was with 8” rims. Not sure if the 5 gallon pal is big enough for the 12” rim. I will see if I can find the video. 1 Share this post Link to post Share on other sites
AHenry014 128 #24 Posted August 13, 2019 On 8/10/2019 at 5:33 PM, adsm08 said: Best purchase i made to help mount tricky tires like the above distorted ones. I just mounted four narrow trailer tires this past weekend and couldnt have done it without my cheetah (knockoff amazon one but same function). Share this post Link to post Share on other sites
