zlimmy 78 #1 Posted August 5, 2019 (edited) Hi all! I'll have no luck sourcing a bearing to my spindle from anywhere. I only need one, and maybe someone has one in ok condition lying around for sale. I also need it shipped to Norway. Thanks VID_20190806_002617.mp4 Edited August 5, 2019 by zlimmy Typos Share this post Link to post Share on other sites
ol550 838 #2 Posted August 5, 2019 Where is it used? Share this post Link to post Share on other sites
zlimmy 78 #3 Posted August 5, 2019 Just now, ol550 said: Where is it used? Inside wheel, two in each. My other 3 are surprisingly tight. This one is wreck... 😥 Share this post Link to post Share on other sites
pfrederi 19,099 #4 Posted August 5, 2019 Front wheel 1" spindle you have a problem. My want to consider using a trailer hub set for 1" axles with roller bearings ... 1 Share this post Link to post Share on other sites
zlimmy 78 #5 Posted August 6, 2019 10 hours ago, pfrederi said: Front wheel 1" spindle you have a problem. My want to consider using a trailer hub set for 1" axles with roller bearings ... Yes, that was my initial taught also. But since i want to keep it as stock as possible for now, and already have used a big pile of money on it. I'm trying to go this cheaper road hopefully... 🙂 Share this post Link to post Share on other sites
953 nut 62,646 #6 Posted August 6, 2019 If you have a good industrial supply store near you they may be able to match it up for you. You could check with Grainger Industrial Supply in the US, they do global shipping and can match it up if given a good set of dimensions. https://www.grainger.com/?gclid=CjwKCAjwyqTqBRAyEiwA8K_4O2ZqRyoT63aw5nIVeaVMhSLg9yVp-Etknpd1hy4uiJ08mPjPCKbOGBoC7zEQAvD_BwE&ef_id=CjwKCAjwyqTqBRAyEiwA8K_4O2ZqRyoT63aw5nIVeaVMhSLg9yVp-Etknpd1hy4uiJ08mPjPCKbOGBoC7zEQAvD_BwE:G:s&s_kwcid=AL!2966!3!56874964893!e!!g!!grainger near me&cm_mmc=PPC:+Google+PPC 2 Share this post Link to post Share on other sites
bottjernat1 2,194 #7 Posted August 6, 2019 Im not sure if these folks ship overseas i believe so. But i have bought many bearings,seals and bushings form them. Might try https://www.motionindustries.com/taxonomy/Bearings/browse/en Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,791 #8 Posted August 6, 2019 The Heim RF 16-30-16 may be the dimensions ID - 16/16" = 1" OD - 30/16 = 30/16" = 1-14/16" = 1-7/8" (Width - 16/16" = 1" is not correct) Measures 1/2" wide Is this a flanged bearing with balls? Garry Share this post Link to post Share on other sites
pacer 3,177 #9 Posted August 6, 2019 Where does this bearing go?? Transmission/differential?? I've got some differential parts from a busted D-180 case.... Share this post Link to post Share on other sites
zlimmy 78 #10 Posted August 6, 2019 (edited) When measured, it reads: 1 x 1-7/8 x 1/2 inch. It's a flanged, ballbearing used on front wheel / spindle. Edited August 6, 2019 by zlimmy Share this post Link to post Share on other sites
pacer 3,177 #11 Posted August 6, 2019 OK, shud have caught that earlier! As for that bearing, I did as pfred suggested and adapted trailer spindles, theyre as common as dirt --- over here at least. Share this post Link to post Share on other sites
Marv 992 #12 Posted August 18, 2019 I have 2 good used ones from D200 front wheels. Do you still need them? Marv Share this post Link to post Share on other sites
