sergt3 8 #1 Posted August 2, 2019 picked up a horse with a blown motor, no decals, its a briggs engine looks to 8-10 hp, its a 4speed with hi-lo range, the only numbers I could find were on a tag..91-11B801-22462 with 9080 under it..any help would be great..it has a 42 rear discharge deck Share this post Link to post Share on other sites
Sparky-(Admin) 24,946 #2 Posted August 2, 2019 Here what you have: 91-11B801 1979 C Series Garden Tractor C-111 8-Speed Briggs 252417-0198-01 11 Wheel Horse 103916 That Briggs is an 11HP. And welcome to a Red Square! 2 1 Share this post Link to post Share on other sites
sergt3 8 #4 Posted August 2, 2019 2 hours ago, Sparky said: Here what you have: 91-11B801 1979 C Series Garden Tractor C-111 8-Speed Briggs 252417-0198-01 11 Wheel Horse 103916 That Briggs is an 11HP. And welcome to a Red Square! thank you mike your the man..at least now I know what im looking for..on the same note will a kolher mount up or should I stay with the briggs Share this post Link to post Share on other sites
Sparky-(Admin) 24,946 #5 Posted August 2, 2019 K series or Magnum series Kohler will work just fine. Little rewiring and that’s about it. Share this post Link to post Share on other sites
953 nut 65,089 #6 Posted August 2, 2019 11 minutes ago, sergt3 said: will a kolher mount up or should I stay with the briggs When you have selected an engine for your new please post some information about the C-111 and the engine that will power it and we will help you get it working. Share this post Link to post Share on other sites
sergt3 8 #7 Posted August 2, 2019 10 minutes ago, 953 nut said: When you have selected an engine for your new please post some information about the C-111 and the engine that will power it and we will help you get it working. thank you Richard you guys rule..and thank you for your service 1 1 Share this post Link to post Share on other sites
rjg854 12,929 #8 Posted August 2, 2019 to the Square, the more the merrier! 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,126 #9 Posted August 2, 2019 Click on the fuzzy picture Garry Share this post Link to post Share on other sites
sergt3 8 #10 Posted August 7, 2019 here is the beast c111 8 speed, hole in the side size of a grapefruit, hopefully I have one coming, then the fun begins 4 Share this post Link to post Share on other sites
Pullstart 69,587 #12 Posted August 8, 2019 ! It looks clean enough to get going again... once you put the grapefruit back in the hole! 1 Share this post Link to post Share on other sites
sergt3 8 #13 Posted August 8, 2019 that is going to be the challenge..never did an engine change over..if I get hung up I know I can get help from redsquare 1 Share this post Link to post Share on other sites
953 nut 65,089 #14 Posted August 8, 2019 8 hours ago, sergt3 said: I know I can get help from redsquare Share this post Link to post Share on other sites
Pullstart 69,587 #15 Posted August 8, 2019 It’s no worry on these little guys! A fuel line, a couple cable clamps, a couple wires and some bolts! 1 Share this post Link to post Share on other sites
