04fxdwgi 1 #1 Posted April 12, 2009 For anyone interested, I have assembled a parts conversion chart for my tractor, making it MUCH easier (and cheaper) to get parts. So if you have the same, here it is: '93 520H machine '91 60" deck Engine Oil filter NN1043 Group7 V195 Purolator L10241 FRAM PH3614 Wix 51374 Transmission filter 25416-99C Purolator L14670 Fram PH2844 Wix 51410 Main Drive Belt 114895 Gates 6983 or B-83 Dayco L583 Mower Drive Belt 113072 Gates A100 Dayco AP100 Mower Belt 112449 Gates B128 Dayco BP128 Gator Mower Blades 20.5" x 5/8" hole Oregon 90-424 96335 Bailey's online OEP 96335 Fuel Filter NN10506 Air Filter 82-0660 Purolator A12283 Fram CA140 WIX 46094 Air Pre-Filter NN10176 Spark Plugs Champion RH14-YC .25 gap Fuses rear Cigar lighter 10 Amp rear ctr Lighting fuse 15 Amp front ctr Main Fuse 25 Amp front Charging system fuse 30 Amp Spindles Housing 113516 Shaft 113513 Bearings (see below) 113514 Complete Assy 111013 Looks like there were 2 iderations of the shaft, a 25mm shaft and a 1" shaft, measure to be sure of the correct bearings. 25mm shaft 6205-RS 1" shaft 6205-16-RS Mower bearing Toro 113514 ID 0.984 25mm 25.04mm OD 2.0472 52mm 52mm W 0.5906 15mm 15mm RS=Rubber seal 1 side 2RS=Rubber seal both sides (fully sealed, non greasable) Share this post Link to post Share on other sites
