AHS 1,566 #1 Posted July 30, 2019 It’s a C 1100-8 with a brigg. The Briggs is blown, the body is good... you know what I’m getting at!! Will a kohler fit in there? I’m sure they had all the frames drilled for Kohlers? Right? Thank you. Share this post Link to post Share on other sites
ebinmaine 75,840 #2 Posted July 30, 2019 That is absolutely a conversion that can be done. I've never done it myself but several of us have. @Stepney Perhaps you could fill us in a bit? Share this post Link to post Share on other sites
Stepney 2,356 #3 Posted July 30, 2019 I have a GT-1848 that was a Briggs twin originally, it sat up on a plate steel spacer mount. Holes were already there for a K-series engine. I used an older 14hp. Most of the B&S machines used shaker or spacer plates because the pans are much lower then a Kohler. But regardless, yes the holes ought to be there. Have seen a few where the belt guards didn't line up quite the same, but easily made to look right. 1 1 Share this post Link to post Share on other sites
AHS 1,566 #4 Posted July 30, 2019 29 minutes ago, ebinmaine said: That is absolutely a conversion that can be done. I've never done it myself but several of us have. @Stepney Perhaps you could fill us in a bit? Well once I get it...👍 1 Share this post Link to post Share on other sites
