Wingra 0 #1 Posted July 30, 2019 How should the two adjusting screws be set. I cleaned the carburetor, and I want to make sure it is properly set. Thanks. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,853 #2 Posted July 30, 2019 Initial settings should be in the service manual. These have been determined to allow the engine to run and that is all. Once running they need to be adjusted again for optimum performance. Reason being no two engines are alike and fine tuning overcomes the differences. Garry 1 Share this post Link to post Share on other sites
Wingra 0 #3 Posted August 1, 2019 Garry, Thanks for sending that link. The manual has some great information, and I appreciate your taking the time to provide it. Share this post Link to post Share on other sites
Wingra 0 #4 Posted August 2, 2019 What should the rpm's be for the high and low idle speed? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,853 #5 Posted August 2, 2019 From the operator manual 1200/1600 rpm no load idle speed 3350 rpm no load governed max speed Garry Share this post Link to post Share on other sites
Wingra 0 #6 Posted August 3, 2019 Thanks, Gary. The mower starts well and runs even with the mower for about15 minutes. It turns over but won't start. I started troubleshooting with the least invasive options and then progressed, i.e. checked the belt, checked and greased spindles on the deck, checked and changed the spark plug, changed the air filter and pre-screen, changed the oil and oil filter, drained the gas and cleaned the gas tank, checked the gas filter, and removed and cleaned the carburetor. The problem has not gone away. I want to check the rpms and make sure the high and low speed settings are ok. One issue with the 244 is parts availability. most of the parts are not readily available, and I don't want to pour a lot of money into a machine that isn't worth much. On the other hand, I like working on it. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,853 #7 Posted August 3, 2019 Have you tried loosening the gas cap in case the tank air vent is plugged? Garry Share this post Link to post Share on other sites
Wingra 0 #8 Posted August 4, 2019 Yes. I bought a new gas cap for that model. Share this post Link to post Share on other sites
