Howie 900 #1 Posted July 28, 2019 This was next to my tractors yesterday at the Plymouth tractor show. 8 Share this post Link to post Share on other sites
ebinmaine 81,048 #2 Posted July 28, 2019 Looks very interesting... Share this post Link to post Share on other sites
Howie 900 #3 Posted July 28, 2019 Thought I added two pictures but guess not. Was built on a Wheel Horse frame One eight horse Briggs and four five horse engines. The combinations were set at slightly different forms to work in sync. Also told me he worked and made the WH frames. 3 Share this post Link to post Share on other sites
Howie 900 #4 Posted July 28, 2019 Here is the second one. 8 2 Share this post Link to post Share on other sites
Pullstart 71,482 #6 Posted July 29, 2019 I wonder what the purpose of different power ratings is for? Maybe it takes 8 hp to start 4-5’s at the same time? Pretty nifty creation! It should be at a plow day 1 Share this post Link to post Share on other sites
clueless 3,440 #7 Posted July 29, 2019 , hell, back in the day I had trouble keeping a dodge 6 pak adjusted . 1 Share this post Link to post Share on other sites
ebinmaine 81,048 #8 Posted July 29, 2019 1 hour ago, clueless said: , hell, back in the day I had trouble keeping a dodge 6 pak adjusted . That just means you were normal. I only knew of two older guys back in the 90s that are both probably long since passed.... They could keep those multi carbs adjusted. Six packs in my experience and observation were the most challenging. Both of those guys were a little bit on the ornery side a lot of the time. Probably because they tried to adjust a six pack once in a while. 1 Share this post Link to post Share on other sites
Howie 900 #9 Posted July 29, 2019 Not sure why he used the engines he did. He started the four a couple of times. Started them individually. With setting the rpm's for each set different it did not pull one set down he said. I forget what the rear axle was but was from some small car. Should have gotten down and looked at it closer but that is harder for an old guy. 1 Share this post Link to post Share on other sites
953 nut 70,071 #10 Posted July 29, 2019 9 hours ago, pullstart said: Maybe it takes 8 hp to start 4-5’s at the same time? That is what it looks like to me. Otherwise you need to get three of your friends to pull concurrently with you. 1 Share this post Link to post Share on other sites
