Countdown To Christmas!
Bub43780
Onan engine runs great for a while then will only run at idle
Bub43780
Tractor runs great for a while then starts loping and dies. Will sit and idle all day but when you give it gas starts loping again like carb loading up with gas
troutbum70
Maybe coil overheating or float sticking in carb.
bc.gold
Bad condenser.
bc.gold
Welcome to Redsquare, Bub43780
Edited by bcgold
cleat
Do a compression test to be sure you are actually running on 2 cylinders.
If that comes up good then likely you need to do a good carb cleaning.
