Tractorhead 9,217 #76 Posted April 4, 2020 Just a small adjust i bet, but the Engine sounds good. maybe engage first gently with less rpm and than increase the throttle. Cool 1 Share this post Link to post Share on other sites
ebinmaine 80,740 #77 Posted April 4, 2020 19 minutes ago, Tractorhead said: Just a small adjust i bet, but the Engine sounds good. maybe engage first gently with less rpm and than increase the throttle. Cool Agree with "engage at idle" for sure. You'll find a lot of sickles run a pretty low speed. May want to run it the time at about half throttle (or even less like a Wheelhorse sickle.) Engine sounds great! Don't forget to re-torque the head. Good change to your audio as well. 2 Share this post Link to post Share on other sites
Pullstart 71,259 #78 Posted April 4, 2020 Thanks for the input fellas! I did try shortly after to run at low rpms and it helped a bunch. Remember too, the David Bradley engine has a very small engine pulley, so it’s overdriving already. Does it seem out of balance with the wider bar, or just too much rpm still? It shakes like crazy! 2 Share this post Link to post Share on other sites
ebinmaine 80,740 #79 Posted April 4, 2020 If there is a way to disconnect the cutting bar from the pulley assembly, try that, then engage. That would isolate the difference between the cutting bar and the pulley system being the issues. You're shaking may very well be due to centrifugal circular forces changing to side to side vibration. 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #81 Posted April 4, 2020 I know you did a lot of work into alignment, but if you able i would suggested to build a second „reducer pair“ in the Drivetrain. 2 pulleys in different sizes, maybe you have them in spare, that could solve you speed Problem and the disalignment wasn‘t that critical. I would guess 1/2 the speed you use now and you‘re fine. About the Shaking, 😂 i see the wobble on your Hood, looks funny. to remove that shake or wobble there are 2 simple solutions: 1. reduce the movement speed 2. Work with more counterweight on the opposite of the sicklebar lever. As i seen, there is allready a counterweight on the edge, maybe you can exchange it with some heavier, that will eliminate the shaking a bit better. I have the same result on my Hedgetrimmer i built, i work with lower speed, than the shaking goes low, so i must drive very slowly, but it works perfect with low speed even on thicker branches it cuts like a knive in butter. may you have a doublepulles from an electric clutch, there is the alignment not too differently, or you dealing with a Lathe and built one yourself. 2 shorter Belts and you are back in Business.👍 1 Share this post Link to post Share on other sites
Pullstart 71,259 #82 Posted April 4, 2020 4 minutes ago, Tractorhead said: I know you did a lot of work into alignment, but if you able i would suggested to build a second „reducer pair“ in the Drivetrain. 2 pulleys in different sizes, maybe you have them in spare, that could solve you speed Problem and the disalignment wasn‘t that critical. I would guess 1/2 the speed you use now and you‘re fine. About the Shaking, 😂 i see the wobble on your Hood, looks funny. to remove that shake or wobble there are 2 simple solutions: 1. reduce the movement speed 2. Work with more counterweight on the opposite of the sicklebar lever. As i seen, there is allready a counterweight on the edge, maybe you can exchange it with some heavier, that will eliminate the shaking a bit better. I have the same result on my Hedgetrimmer i built, i work with lower speed, than the shaking goes low, so i must drive very slowly, but it works perfect with low speed even on thicker branches it cuts like a knive in butter. may you have a doublepulles from an electric clutch, there is the alignment not too differently, or you dealing with a Lathe and built one yourself. 2 shorter Belts and you are back in Business.👍 I toyed with the idea of a jackshaft to reduce the drive speed, thanks for the reminder! I don’t think it’ll be too hard to move the belt to the outer PTO groove and jack shaft back into alignment I bet too, if I build solid engine mounts for the cradle it’ll help reduce the huge vibrations! 1 Share this post Link to post Share on other sites
Pullstart 71,259 #83 Posted April 10, 2020 I am looking around for some deck parts to help @FAST with some needs and figured out the deck double pulley might be what I need to slow the mower drive down. I might even be able to incorporate a spindle into the mix to get my fix! 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #84 Posted April 10, 2020 Looks a good idea. 1 Share this post Link to post Share on other sites
WHNJ701 4,173 #85 Posted April 10, 2020 1 hour ago, pullstart said: I am looking around for some deck parts to help @FAST with some needs and figured out the deck double pulley might be what I need to slow the mower drive down. I might even be able to incorporate a spindle into the mix to get my fix! what pulley are you looking for? Share this post Link to post Share on other sites
Pullstart 71,259 #86 Posted April 13, 2020 On 4/10/2020 at 5:25 PM, jabelman said: what pulley are you looking for? He needed the outer pulleys and spindle shafts. I am toying with the idea of using the center double pulley as a jack shaft to slow the DB mower down. I found two 5/8” shaft pulleys that are 9” and 6-3/4” diameters, I’m going to try to turn the big hub down to receive the small hub and use the long spindle shaft to build it all with. Share this post Link to post Share on other sites
Pullstart 71,259 #87 Posted April 13, 2020 I turned the jaws around then cut a pocket in the big pulley and the little one is a slip fit inside there. It’s not quite short enough, so I’m going to chuck the spindle shaft up in the lathe and try to relieve the blade end of it to get some more length out of the matter. 4 Share this post Link to post Share on other sites
Pullstart 71,259 #88 Posted April 13, 2020 This aughtta do the trick! 2 1 1 Share this post Link to post Share on other sites
Pullstart 71,259 #90 Posted April 13, 2020 I think I need a bit more room... Share this post Link to post Share on other sites
Tractorhead 9,217 #91 Posted April 13, 2020 50 minutes ago, pullstart said: I think I need a bit more room... Maybe it is a solution if you set a sqarepipe with about 2“ above the top of the Sicklebar column where the squarepipe is allready welded in and welded on this a mounting plate for the Jackshaft. Than you will be as far as i can esimate it in the pictures are able to lift it about 1,5 to 2“ in the height. At least you shall be able to forward it also about 3,5 - 4“, what shall be enough space to not touch the Hood and even be able to open it later for Service purposes. but this are just estimates on the Pics. 1 Share this post Link to post Share on other sites
Pullstart 71,259 #92 Posted April 13, 2020 Yep, I’ll work on a mount plate for the spindle, then figure out where it might fit best. Using the outside pulley, I have more room to clear the hood too. 1 Share this post Link to post Share on other sites
ebinmaine 80,740 #93 Posted April 13, 2020 Looking great so far Kev! 2 Share this post Link to post Share on other sites
Pullstart 71,259 #94 Posted April 13, 2020 1 minute ago, ebinmaine said: Looking great so far Kev! It’s gonna look better when my beverage doesn’t foam over when I’m mowin’ the field! 3 Share this post Link to post Share on other sites
ebinmaine 80,740 #95 Posted April 13, 2020 1 minute ago, pullstart said: It’s gonna look better when my beverage doesn’t foam over when I’m mowin’ the field! Do we need a specially constructed highly engineered vibration resistant cup holder?? 1 2 Share this post Link to post Share on other sites
Pullstart 71,259 #96 Posted April 13, 2020 1 hour ago, ebinmaine said: Do we need a specially constructed highly engineered vibration resistant cup holder?? Nope, just a properly balanced mower that doesn’t shake me and Steve to pieces 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #97 Posted April 13, 2020 When i was a youngster, we had in Munich a U.S. Base, called the Mc Graw Area. There was each year a nice Festival on spring. On that Festival they had each year a Bullriding what was allready funny enough, until we developed the idea, to ride with one hand in the strap and a Cup of your beloved Beverage in the other hand..😂 We payed each another the full Cup the the rider can drink what was in the Cup after the Bull stops. One of my funniest memory😂😂😂😂 1 1 Share this post Link to post Share on other sites
Pullstart 71,259 #98 Posted April 14, 2020 Found some various sized belts, came up with a mock-up. It doesn’t look too out of place! 4 Share this post Link to post Share on other sites
Pullstart 71,259 #99 Posted April 14, 2020 The railroad piece / anvil does a decent job holding the weight of the spindle, maybe it needs to become part of the Edward Scissor Hands attachment? 1 2 Share this post Link to post Share on other sites
Tractorhead 9,217 #100 Posted April 14, 2020 (edited) I doubt that it will be in place while mow...😅 or did you plan to install Railway’s in you fields?😂 Think it‘s allready heavy enough, you don’t need more Weight even against shaking. except you add a bit more to the Counterweight or extend the length as you allready mentioned. How about a Top cover, where the Spindlemount for the Jackshaft will be Welded on. In that case you are simply able to disassemble the Top cover for service the Spindle of the Sicklebar either. Just a thought Edited April 14, 2020 by Tractorhead 1 1 Share this post Link to post Share on other sites
